It is currently Sun Jun 14, 2026 2:30 am
 Post subject: Using gasket sealant
PostPosted: Tue May 16, 2006 10:18 pm
So, I was just talking to a couple guys here at work about putting on this new trani pan I got, and 1 guy says not to use any sealant, and the other says to use ultra copper. What do you guys think?????
PostPosted: Tue May 16, 2006 10:34 pm
Maybe just a very thin coat on the pan only, to act as a glue to hold the gasket in place untill bolted on. That would be my guess. :?
PostPosted: Tue May 16, 2006 11:25 pm
I use gasketcinch, silicon can disslodge and clog up the filter or get into the valve body.
PostPosted: Wed May 17, 2006 10:12 am
I agree... Silicon or RTV as it is a bad idea, Felpro makes a very nice tranny pan gasket, I have used them on all of my transmissions and have never had a problem with leaks, Dry and Tight is the best answer.
'76 MUD project, 1 ton axles, lockers, 20" Lift, Big Smallblock, On board air, 54" Boggers, Hummer Double beadlocks, External Rollcage... in the works.
PostPosted: Wed May 17, 2006 2:49 pm
i just put a new trns in my truck and iv never used any silicone ive always just use the gasket and never had a leak the normal reason they leak is because people put them on to tight and crack the gasket
PostPosted: Wed May 17, 2006 11:13 pm
Japanese Redneck
most of the time I dont use anything at all. On occasion I will sometimes use a spot of gasgacinch on the 4 corners if im having a problem keeping it in place but if properly tightened down u shouldnt have to rely on it for sealing ur pan. the gasket by itself should do just fine.
BTW if you do use sealer or cinch then u will spend like 45 min scraping the gasket off the pan the next time u take the pan off.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
