It is currently Sun Jun 14, 2026 2:30 am
 Post subject: rotary motors
PostPosted: Wed Mar 01, 2006 3:09 pm
are rotary motors say like a twin turbo 13m able to be put in these trucks? cause i have a guy here locally that has an rx7 shop. also it would be good cause its 5 speed and you can have more upgrades plus turbo.
PostPosted: Wed Mar 01, 2006 4:36 pm
Banishment Pending
well the Aussies are putting them into Gemini's so I would assume that you could fit on into a Luv.
PostPosted: Wed Mar 01, 2006 7:27 pm
I have thought of that myself I think it would be easy to do . if my new motor ever takes a dump i just might do it, go for it man and lets us know how it turns out
PostPosted: Thu Mar 02, 2006 12:27 am
I don't see any reason why it wouldn't fit. Rotaries are a small package compared to piston engines.
PostPosted: Thu Mar 02, 2006 2:59 am
Only issue I can think of is gearing. Rotaries put out some serious RPMs and often have differential gears to match.
I knew someone years ago who dropped a SBC into an old Mazda rotary pickup. The rear end was geared so high it was a challenge to get 55MPH out of it. The driveline ended up giving out after a week or so and took care of removing the rear end for him though.
PostPosted: Thu Mar 02, 2006 8:03 am
Yeah gearing is the only realy big thing. The Mazda REPU pickups (yup you guessed it a B series whith a rotory 8O ) had 4.77 gears in the rear end. The bigest problem whith the rotories is they have NO low end power, and if you lug em the engne is done...
