It is currently Sun Jun 14, 2026 2:27 am
 Post subject: fuel pressure question
PostPosted: Tue Dec 27, 2005 2:49 am
I have a newly rebuilt 327 sitting on my engine stand with a weiand tunnel ram and 2 holley 4160 450 cfm mechanical secondary carbs. The motor is suppose to put out around 380-400 HP. My question is what kind of fuel pressure do I need to keep this thing from starving itself. I just ordered all the plumbing parts from summit including pressure regulator and gauge.
PostPosted: Tue Dec 27, 2005 6:23 pm
Japanese Redneck
7-10 psi but it also depends on what the GPH rating of your pump is at those pressures.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Wed Dec 28, 2005 9:35 pm
I dont even have a fuel pump for it yet. I was also wondering if I should use an electric pump or a mechanical pump. I will probably go with electric. Its been a slow work in progress. Thanks for the info.
