It is currently Sun Jul 05, 2026 12:07 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
PostPosted: Tue Sep 16, 2003 2:31 pm
My Luv is making a "whole lotta torque". Is there a stronger rear end that I could possibly find in a junk yard that would bolt pretty much right up? The first time mine hooks up now I'm pretty sure I will be pushing it on the trailor for the ride home. :cry:
PostPosted: Tue Sep 16, 2003 2:55 pm
Japanese Redneck
you get what you pay for.... you try to go the budget route, its just gonna break on you at some point anyway.
Some people use a Dana 44 scavenged out of a mail delivery Jeep. Some ppl say that the right width Dana 44 can also be found in a mid 90's Honda Passport. a 44 should hold up to a mild small block making 400hp. What exactly are you running for parts in this motor? and what will its main purpose be? Street? Strip? strip only?
I would personally hang a narrowed 9" in it at least.
PostPosted: Tue Sep 16, 2003 3:54 pm
I have a 350 .030 over, Holley 650, stock aluminum intake from '69 camaro, Lunati cam .470 lift 298/288 dgrees, Headman headers, 882 heads, it had 4.10 gears when I got it but I have changed them to 3.73(couldn't run but 60 mph down the highway), and a 350 trans. That's all I can think of now, I just got the truck about a month ago, it's been a lot of fun already. I took it to the track for the first time last friday night. It was really hard to keep it from spinning for the first 1/8 of a mile, the last eighth was awesome though. lol It's going to see some street driving not much, weekends out for a ride that's about it. Thanks for the input!!
PostPosted: Tue Sep 16, 2003 4:08 pm
Japanese Redneck
Dana 44 will be fine for your application (approximately 300-325hp). invest in some 28x10 slicks. That will cure your wheel spin problem. probably wont even have to do a burnout either. just pull up to the line and drop the hammer.
 Post subject: 12-bolt GM
PostPosted: Wed Sep 17, 2003 8:29 am
I use a 12-Bolt GM rear.
They're strong, easy to find, cheap, and easy to find parts for. It takes a little work to make it fit, but you'll have a bullet-proof rear.
Definetly worth it if you have $100 or so and a free weekend.
PostPosted: Wed Sep 17, 2003 9:06 pm
I like the sound of a 12 bolt. When it can handle what it's putting to the ground, I'm going to put more to the ground lol. But where do you guys learn this stuff? Is there a book or do you just buy it and say"how the hell do I make this fit?" lol. Can you give me a little bit of an idea of what I will be getting into?
PostPosted: Wed Sep 17, 2003 9:20 pm
Japanese Redneck
It's going to have to be narrowed.... and unfortunately GM rear ends are costly to narrow. i hang a 9" in everything.
I picked mine up out of the Recycler for $150, had MIT (mechanically Inclined Technicians) narrow the housing for $150, Currie enterprises narrowed the axles for $150 (although you can get nice aftermarket alloy axles already the correct width for about 350 now), letsee..... factory LS 3rd member with 3.70 gears $200 in the recycler. slap it all together and there you have it.
Expect the same for the 12 bolt but add $$ for C clip eliminator kit, new posi carrier if you want to go with any deep gears, posi carrier shim kit for the re-gear. when it all ads up, its about twice as much as a 9"
PostPosted: Wed Sep 17, 2003 9:43 pm
i run a ford 8" in mine out of a maverick i have to run alot of backspacing on the rims though. it`s proven to be durable so far my ruck runs in the 11s i haven`t had any problems
PostPosted: Wed Sep 17, 2003 10:35 pm
Japanese Redneck
8" is supposed to be stronger than a Dana 44 or a 12 bolt. I ran one for years in my high school 11 sec LUV. it was alive and kickin the day I pulled it out to put the 9" in.
PostPosted: Thu Sep 18, 2003 12:18 am
just finished putting a mavrick 8 inch in mine running 5.5 on the backspaceing everything looks good so far. had to stop working for a bit had surgery but now i'm healed up and it's time to work again
PostPosted: Thu Sep 18, 2003 9:54 am
Go 9 inch, there cheap, you can get them in ANY wrecker yard and you can respline them pretty cheap if the width is not right.
PostPosted: Thu Sep 18, 2003 11:27 am
hey i just saw the thing on the mail jeep rear. what gears would likely be in those and does it matter if its a mail jeep or a jeep like a cj series?
PostPosted: Thu Sep 18, 2003 12:10 pm
Japanese Redneck
Dont remember gear ratios in those things. I will ask a friend about that and how good the CJ5 rears are. My bro used a 44 out of a Wagoneer I think.
PostPosted: Thu Sep 18, 2003 12:53 pm
hey forgot a question. what do those have for a locker like a limited slip?
and how wide is one for a wagoneer, and what year.
thanks
PostPosted: Thu Sep 18, 2003 3:38 pm
Japanese Redneck
yes, a LS carrier. as far as the year and width, I dont remember. we did that conversion almost 20 years ago. after asking around i think your best bet is toing to be a Honda passport or Isuzu rodeo though. They are probably gonna be easier to find and get parts for. CJ's and mail jeeps are getting hard to find.
PostPosted: Thu Sep 18, 2003 4:09 pm
alot of the mail jeeps came with 4.10 s and a posi to help when they were in bad weather. as far as the cj 5 some came with 44 some had a dana 36 you don`t want the ones with the nut on the end of the axle some danas had that and were pretty weak unless you plan on buying new axles.
PostPosted: Thu Sep 18, 2003 8:30 pm
I USED A MAVRICK 8IN REAR WENT RIGHT IN HAD A DRIVE SHAFT MADE
HOLDS UP MY LIL 500HP JUST FINE 4.62 GEAR MINI SPOOL ALSO
PostPosted: Fri Sep 19, 2003 8:51 am
Japanese Redneck
Plus some of the 8" parts line the brakes, some of the axles etc. are transferrable to the small bearing 9"
PostPosted: Sun Sep 28, 2003 5:12 pm
After some looking around I think the maverick rear end is the way to go. So should I just be able to change my yoke on my drive shaft or will the length need to be changed too? I just want to make sure I have enough money put back so I can do all this at one time. Don't like missing to many race weekends. :lol:
 Post subject: rear end
PostPosted: Tue Sep 30, 2003 12:35 pm
the dana 44 is a good rear you can get spool and gears from offroad racing or randy,s ring and pinion i still run the stock luv in mine and run mid 10 sec on 75 shot the #4 street king jose runs a dana 44 and runs mid 9,s on spray so luvsadrag where is pic of truck i got pic do you??????????if you are scare get you a dog LOL HAVE TO GET YALL GOING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
