It is currently Mon Jun 08, 2026 4:15 pm
PostPosted: Sat Sep 08, 2007 8:05 pm
i know this is the 10 millionth post on this but i did a search a couldnt find what i was looking for. What do I need to get to do the conversion for my 79 4x4, without going to the junkyard to get parts(not available for me). thanks
1979 4x4 LUV, rebuilt 1.8 and 27" bald tires
 Post subject: .
PostPosted: Sat Sep 08, 2007 10:13 pm
Option 1
Call Pertronix and ask for
18433 Reluctor Ring
16430 Module Kit
Typical installation here.
http://www.ttalk.info/Tech/Pertronix_Into_TD.html
Maybe throw in an MSD[/url]
FIAA: Color Guard
PostPosted: Sat Sep 08, 2007 11:11 pm
PITA Old Fart
Option 2.
Check on http://car-part.com/ and find an electronic ignition module and matching distributor from a '80-'82 Luv, Imark, or Pup with a G180 or a G200 engine.
Do the simple 2 wire conversion shown in the complete instructions with pictures that is in the info section on this site's front page.
http://www.luvtruck.com/pdf/LUVignitswap.pdf
Add an Accel or a Pertronix higher output coil.
Either option will bump up your spark a bunch and won't keep you from passing smog. The old points-type ignition just isn't that great. It tends to fade a bit at higher rpm's.
BTW..while you are at it...you might as well switch your stock 35 amp alternator for a 50 amp one. Just have the guy at the parts counter look up the one for your truck that comes with air conditioning, (they are both the same price), then run a heavier guage wire from your alternator plug to your battery, and throw in a couple of 50 amp blade fuses where your fusable links that connect that wire to the battery are.
PostPosted: Sun Sep 09, 2007 12:05 am
option 3, click this link.
http://forums.luvtruck.com/viewtopic.php?t=13638
PostPosted: Sun Sep 09, 2007 4:53 am
PITA Old Fart
Option 4 :lol:
PostPosted: Sun Sep 09, 2007 5:30 pm
Here's my Pertronix install, on an '80. Ordered the parts from Summit.
http://forums.luvtruck.com/viewtopic.php?t=14580
PostPosted: Mon Sep 10, 2007 2:45 pm
thanks guys
 Post subject: Re: .
PostPosted: Wed Sep 12, 2007 3:40 pm
sleeps at LUVTruck.com
79-LUV'r wrote:
Option 1
18433 Reluctor Ring
16430 Module Kit
do you know how much it would cost to buy the reluctor ring and module kit?
PostPosted: Wed Sep 12, 2007 4:25 pm
I went to Summit and priced them after reading this post.
Around $20.00 for the ring,and $90.00 for the module.
 Post subject: Re: .
PostPosted: Wed Sep 12, 2007 7:48 pm
luvmytruck wrote:
79-LUV'r wrote:
Option 1
18433 Reluctor Ring
16430 Module Kit
I got my whole (1741)"kit" for $65, I bet they would give you a good price if you called them needing those individual parts #'s
FIAA: Color Guard
PostPosted: Sun Sep 16, 2007 10:14 pm
Seems like I got both shipped for around $90?
