It is currently Mon Jun 08, 2026 3:18 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2, 3  Next
 Post subject: I Luv my "new" Truck :)
PostPosted: Tue Mar 20, 2007 7:18 pm
The "DIY" paint and polish is finished... now I know how poor Daniel`san felt :D
Here's a bit of a timeline. Some of these are not great pictures, had to use my Razr to take some as my digi-cam batteries always seem to be dead at the worst time.
Before
Image, Prep stage Image
Image, Image
Image, Image
Image, Image
Image, Image
Added a Weber, Image,Image
FIAA: Color Guard
 Post subject: paint job
PostPosted: Tue Mar 20, 2007 8:20 pm
you did that with a paint roller? how many coats? can you use masking tape on the finished paint job? I'm interested, but, I'll need to paint the 4x4 and stripes over the new paint? Will the masking tape "peel" off the new paint??????
1980 Chevy Luv 4x4 Mikado
the "Ole Man from Spokane"
PostPosted: Tue Mar 20, 2007 8:21 pm
btw, it's beautiful!!! I'm impressed!
PostPosted: Tue Mar 20, 2007 9:04 pm
Roller, yes
Coats 10
Masked yesterday to repaint the black skirt, no problem. I was a little paranoid so before I stuck the tape to the paint, I'd dab or drag it accross the leg of my jeans just in case.
And, Thanks, I kinda like it :wink:
FIAA: Color Guard
PostPosted: Tue Mar 20, 2007 9:17 pm
Just saw your posts in the Moparts thread to end all threads & had to come back here to post my most exalted admiration. Looks great!!
I wish I had cut mine when it was fresh with a buffer & some compound but it's been a few months now.
I think the easiest coarse now is gonna be an agressive wetsand(1000?), 1 more coat of paint, & buff within 48 hrs.
Congrats Mr 79LUV'r!! WELL DONE!!!!!
There will be some that simply will not believe you rolled it.
Don't bother trying to convince 'em otherwise, just smile. :roll:
 Post subject: .
PostPosted: Tue Mar 20, 2007 9:41 pm
Thanks man, glad you like it. Hope any of that info helps ya out. Sounds like you got a good idea, wetsand what you have, wash, wipe down with mineral spirits. Only I would do 2 thin coats, better to have it and not need it, than need it and not have it right? Are you set on which paint you are re-coating with? Look forward to seeing your success.
FIAA: Color Guard
PostPosted: Tue Mar 20, 2007 9:45 pm
mind sharing the total cost?
looks very snazzy :smt112
 Post subject: .
PostPosted: Tue Mar 20, 2007 9:52 pm
'bout $100 bux, give or take.
Even at twice that, I'd still do it again. Very satisfing to stand back and say "I did that", thanks to the info from the guys at Moparts forum.
FIAA: Color Guard
PostPosted: Tue Mar 20, 2007 10:14 pm
Very interesting...
PostPosted: Tue Mar 20, 2007 10:32 pm
Looks great. Maybe my son and I will tackle the white truck. Got a bunch of body work first though. :cry:
PostPosted: Tue Mar 20, 2007 10:39 pm
That's cool, my oldest son just bought himself an 89 Chevy pickup. Looking forward to getting him started on his. Should be a good cadidate, has the usual late 80's era horrible clearcoat peel.
FIAA: Color Guard
PostPosted: Wed Mar 21, 2007 1:47 pm
Looks great! I also have to repaint my Chevy Luv....I have been focusing on all the mechanicals over the past year and have it running smoothly now.....time to focus on the exterior.
Funny you should mention the 1980s era clear coat peel. I have a '80 Luv and a first generation '89 SHO and both have the clear coat peel. My SHO runs likes like a bastard on fire but definitely looks like a modern day rat rod with all the primer, clear peel and a few dents...:) I guess I like that look or I would have done something to it by now...
Hats off to you!
http://bp3.blogger.com/_RApJIlqIIM4/R8d ... C-042S.JPG
 Post subject: .
PostPosted: Wed Mar 21, 2007 6:29 pm
Ok damnit....what's the deal with points?
Burned and replaced a set over the weekend after the engine did one of those rare "diesel" sputter to a stop shutoffs. Installed my MSD system earlier , drove to WalMart with the wife shutdown fine, stopped to get some other stuff, shutdown fine, drove home, was commenting at how much better it started and ran in general, also noticed my tach had stopped doing jiggly dance when I accelerated past 3000 rpm, now it was nice and smooth like a tach oughta be. Arrived home, truck did another "diesel" sputter shutdown. Came back out about 10 minutes later. No start.....sigh. I may have to buy a sack full of points.
Anyway, here's the MSD rig installed, wasn't too hard to do inspite of the strange instruction sheet.
FIAA: Color Guard
PostPosted: Wed Mar 21, 2007 7:52 pm
So this MSD is an electronic ignition system that still utilizes points? :?
PostPosted: Wed Mar 21, 2007 8:38 pm
Far as I can tell by the instructions, unless there's some way to bypass the points that I'm not aware of. That was actualy what I had in mind getting the system... being as how I remeber hating point ignition so much. Maybe I need a different distributor system with it. The guy at O'rileys mention a "mallory" something or other he ut in his old Impala, that eliminated points, said it droped into the dizzy where the points used to be.... no idea :?
http://www.msdignition.com/pdf/5200_frm18162.pdf
Anyone out there have and MSD setup on a stock Luv, that does not use points?
FIAA: Color Guard
PostPosted: Wed Mar 21, 2007 8:53 pm
I don't recall mallory making that, I thought it was/is Pertronix. Also, most points run 6 volts, there is a ballast resistor wire dropping the voltage down to six, so did you do away with the ballast wire when yoi installed the MSD set up? The box may be putting too much juice to the points, causing them to fail. Just shooting in the dark here...
 Post subject: .
PostPosted: Wed Mar 21, 2007 8:59 pm
I also intsalled the MSD .08ohm ballast resistor, honeslty I would have thought is was all the MSD setup fault, except this same thing happened to me over the weekend before the MSD was even outta the box. So now I'm kind chasing my tail wonder which was coincedence etc.
For now, I have taken out the Blaster coil thinking it may be the culprit, now running the MSD 5200+ballast resistor+ stock coil.
Any clue as to what causes the occaisional hessitant engine at shutdown?
FIAA: Color Guard
PostPosted: Wed Mar 21, 2007 9:06 pm
I see what you mean about the Pertronix system.... looks hopeful. Expensive though. :?
http://www.vintageperformance.com/retro ... gnitor.htm
FIAA: Color Guard
I'd consider using the Pertronix conversion. Ditching the points might be a good thing. I had a 69 firebird with the Sprint 6 overhead cam engine that kept eating the points. Bought the Ignitor set up, problem solved. It was about a 20 minute install. Cost about 50 bucks back in 98. I think I got mine @ Autowrong, but I can't remember. I think Summit or Jeg's sells 'em.
 Post subject: .
PostPosted: Wed Mar 21, 2007 9:13 pm
Thanks for the info T, I'll certainly add that to my wish list.
This looks like the ticket :wink:
http://pertronix.carshopinc.com/product ... id/79/1741
FIAA: Color Guard
