It is currently Sat Jun 06, 2026 10:31 am
PostPosted: Tue Jan 16, 2007 11:51 am
NOW THIS WAS A GRAND OPENING AT A SHOP IN HOUSTON. THEY HAD 2 DYNO PULLS FOR $20. HELL I WAS JUST WONDERING WHAT IT WOULD MAKE. 1ST PULL IS 1 STAGE THE 2ND IS WITH BOTH STAGES...IT DID'NT DO TO BAD FOR A 383 SBC BRODIX TRACK 1X HEADS.
http://s125.photobucket.com/albums/p50/ ... uvdyno.flv
PostPosted: Tue Jan 16, 2007 11:59 am
Cool vid wish I could hear it, sound isn't currently working on my comp. What did it pull?
 Post subject: DYNO
PostPosted: Tue Jan 16, 2007 12:03 pm
701 RWHP FIRST PULL
867 RWHP 2ND PULL
PostPosted: Tue Jan 16, 2007 12:12 pm
Sweet, So Brodix headed 383. Is it a old school 383 (cut down 400 crank) or a new style rotating assemblies, maybe a crate engine? How much you spraying with your 2 stages? What kinda torque are you throwing down?
 Post subject: .
PostPosted: Tue Jan 16, 2007 12:19 pm
NO CRATE ENGINE HEAR...I BUILD EVERYTHING I HAVE AND ONLY SUB OUT THE MACHINE WORK. I EVEN DO MY OWN TRANNYS, REAR ENDS AND WELDING....THATS THE ONLY WAY A POORBOY COULD DO IT..LOL..HERE IS SOME INFO FOR YOU
1976 Chevy LUV All steel and glass windows.2855lbs w/driver. Stock front suspension, redrilled rotors for 5 lug,removable steel font clip and doors. 12 point cage 4 wheel disc 9" ford rear w/ 4.56 gear 31x13.5x15 MT et drags on a 15x14 rim. 2x3 tubing back half with ladder bars and wish bone with antiroll bar. Now the good stuff. 383 sbc Motown block, Callis crank. Eagle Hbeam rods 6", custome JE 13.1 pistons, Comp Cams solid roller 286 @.050 intake 296 @.050 ex .626 intake .646 ex. Brodix Track1X heads and Super Victor 4500 intake fully ported by Creative Flow Management Jesel Shaft rockers. Headers are custom 2-1/8" w/4" collectors and a 3.5" Dynomax Bullet muffler.Speedtech Diffuser Nitrous Plate 200hp right off the tranbrake and another 150hp on a timer, 1150 cfm dominator built by The Carb Shop. Motor dynoed at 648hp @7200. They would not let me spray it on the dyno..said i could but if the dyno broke i would have to pay to fix it. PG tranny w/tranbrake and 4000rpm convertor. I run in the index races in and around the houston area. 5.40 class. It has taken about 3-1/2years to complete. Best time to date breaking the wheelie bars..5.2s @135mph.......one of the fastest 23 degree heaed sbc ya'll find...and there more left in it...Keep on Luvin....QIKLUV
PostPosted: Tue Jan 16, 2007 12:48 pm
Cool thanks for all the info, I like the idea of building everything yourself. It is the only way your know it is right.
I will actually be building a similar engine soon. I am going to be diving into my old school 383 and replacing the bottom end with one of eagle's rotating assemblies part number ESP-B12011030 which sounds similar to what you have basically used only major difference would be the fact I am sticking with a GM block and the dart heads I plan to get from mytmouz. Maybe I can wake up the old car.
5.2's at 135mph in the 1/8 is moving it man. If my calculations are close that would mean 9.3's in the 1/4. I would love to see that mofo run in person. Again thanks for sharing all the info.
 Post subject: time
PostPosted: Tue Jan 16, 2007 1:06 pm
1/4 mile 8.45@165
i need to do a gear change
PostPosted: Tue Jan 16, 2007 1:11 pm
Ah that time I came up with 8.46 @ 165.01 I was forgetting about the combined shot of 350 of your little bottled buddy.
PostPosted: Tue Jan 16, 2007 9:57 pm
very sweet ride!!!
PostPosted: Tue Jan 16, 2007 11:05 pm
damn nice truck quik. sounds real good to. to bad you're not farther north i would like to see it yank the front end up myself.
i seen a pic of a 4 door luv in your set, thats a pretty neat idea lol
AINT RIGHT MOTORSPORTS
PostPosted: Wed Jan 17, 2007 12:36 am
Luvrv8...
You get YOUR LUV to do that and I will consider tubbing my LUV!
8O
Man!
The bed flex and the body lift that thing does is SCARY!
72 L.U.V.
427 SBC-700R4
Mustang II front suspension
LUV perf parts manufacturing
My Devotion to Karl :
 Post subject: flex?
PostPosted: Wed Jan 17, 2007 6:59 am
bed flex, the lower bed side in front of and behind the rear tire need to be anchored from the bed to the chassis. i just have not figured out a way to do that yet..if i weld it it will burn the paint on the other side..maybe fiberglass? glad you guys enjoyed it. i will post some pics of the truck close up in the next coming days.
PostPosted: Wed Jan 17, 2007 4:05 pm
How about some bent straps. They can be sheet metal, flat or round stock. Bend it to fit the bed-body and then to the frame. You can use stainless bolts, nuts, cap nuts or what you think looks on the body. Weld or bolt the other side to the frame.
Other way would to be SS cable, eyelets and a turnbuckle.
HTH
Richard
PostPosted: Thu Jan 18, 2007 8:09 am
Use 3/8 tubing flatten both ends,drill and use SS button head bolts and SS nylocs it would look good and hold up forever.
PostPosted: Thu Jan 18, 2007 9:06 am
TJ good one too. EMT might work too. I have seen both done. Usually before the car is painted. Body reinforcement along the outline of the panel, and across the panel for support.
"You be lookin good"
Richard.
Texas Luv bracket races. Of corse I will be way down on the V8 side :cry:
PostPosted: Mon Jan 22, 2007 7:46 pm
LUVTruck.com's Cornholio
Thats yours too? Man that white truck has some seriously huge balls!
 Post subject: crewcab
PostPosted: Mon Jan 22, 2007 8:11 pm
nope the crew cab is not mine. just somthing i would like to have. but the white truck...you better have a sack if you plan on driving..been trying to get a buddy of mine to drive it but he don't want to.
PostPosted: Mon Jan 22, 2007 8:17 pm
I'd sit down behind the wheel in a heart beat. Looks like it should be a hell of a ride.
PostPosted: Mon Jan 22, 2007 8:39 pm
If you're lookin for volunteers... :lol:
 Post subject: et
PostPosted: Mon Jan 22, 2007 8:41 pm
if you step the spray up on yours??? you could do it.
