It is currently Wed Jun 10, 2026 12:31 am
PostPosted: Sun Feb 04, 2007 3:30 pm
For some reason I like this thread...
PostPosted: Sun Feb 04, 2007 10:16 pm
im glad you guys find this thread interesting, i need somewhere to write down everything im doin so i dont forget it lmao!!!
got some gussets done today.
remember my wrench turning exceeds my welding and cutting abilities by a long shot :lol:
forgot to mention batteries went out on camera and i didnt change the date when i put in new ones.
right hand side
left side
another shot at the x-member
AINT RIGHT MOTORSPORTS
PostPosted: Mon Feb 05, 2007 7:51 am
I see you are get it done,a word of advise though is put a gusset on the inside corner as it will help with twist and strengthen it allot more.
PostPosted: Mon Feb 05, 2007 10:15 am
its gonna get a gusset eveywhere a gusset can go lol
PostPosted: Mon Feb 05, 2007 1:32 pm
well that turned out good awesome it makes me want to go do the work on my Jeep Frame.
About the gusseting issue well I am kind of wondering about totally gusseting the whole frame I would think you need a little bit of give in case you break some drivetrain????
Keep up the Progress your motivating me.
James
PostPosted: Sun Feb 11, 2007 12:31 pm
a few before pics for the hell of it.
now for some progress pics
still need to cut the 9 inch down to fit and order the axles. hoping to be back on the track by march.
PostPosted: Sun Feb 11, 2007 1:33 pm
PostPosted: Sun Feb 11, 2007 3:14 pm
looking good see you in March
PostPosted: Mon Feb 12, 2007 8:26 pm
hey luvit80 i was lookin back at this thread, what size lowering blocks did you use on the rear of your truck?
http://i84.photobucket.com/albums/k8/luvit80/truck.jpg
PostPosted: Mon Feb 12, 2007 9:08 pm
Those are 2'' Their is also a 2 degree shim on the top and bottom of the block in that photo. When I was playing on the setup to better my 60ft. The stance in your pics looks pretty close. You could change the spring perches and not use the block for the same effect. Probably be better than the blocks I have heard of the blocks breaking before. But I have had no problems with mine so far with about 150 passes in the low 7s. and several hundred miles on the street.
PostPosted: Mon Feb 12, 2007 10:07 pm
i was thinking on new spring perches and a mono leaf setup with slide-a-links later on. right now im goin back with stock leafs and slapper bars.
thx for the tip on the shims :wink:
PostPosted: Mon Feb 12, 2007 10:20 pm
I run stock springs and slapper bars that work pretty well. Right now I run about 6 1/2 degrees of pinion angle and run a 1.65 to 1.70 sixty foot with a little slippage havnt got it just right yet.
PostPosted: Tue Feb 13, 2007 10:43 am
what rear gear you run?
PostPosted: Tue Feb 13, 2007 1:20 pm
Started with 4.11 went to 4.33 and now have a set of 4.56 and 4.88 to try. Cant wait for it to get warm. But this thing is gettin up there in RPMS at 70mph, so may be stuck.
PostPosted: Thu Mar 01, 2007 11:55 pm
been busy lately. had my b-day and anniversary in feb so didnt work on much. daughters b-day comin this month and wifes next month lol.
anyway this is what i got done today. the shock mounts are off now.
cut 11 inches out of each side. 37 inches from end to end right now.
i got the moser brng supports and retainers, long studs for the front, all the lugnuts for the weld wheels, (man nuts are expensive!!) and an autometer water temp gauge a few weeks back.
where did you get your lowering blocks?
PostPosted: Fri Mar 02, 2007 7:27 am
Waayyyyyyyyy too much expense and work for me. Must be nice. Wished I could jusy pay someone to do mine. Guess I don't need it for a street truck though.
In your first pics what size tire was on it. They looked like they fir the wells like I want mine to. My 315's I bought I think are way too big to fit the stock wells.
PostPosted: Fri Mar 02, 2007 10:58 am
same slicks that are goin back on it. 28x10.50x15
PostPosted: Thu Mar 15, 2007 6:59 pm
been a while so here is more stuff.
axles should be in next week.
gotta get the lowering blocks and u-bolts yet.
i wanna know what you guys think of this pic. the u-bolt is goin to be close to the weld here. im not sure what to do exactly yet.
im thinking it will be ok just get a bigger u-bolt and go with it.
the right side is the same way.
i need to notch the leaf perches to fit better.
PostPosted: Thu Mar 15, 2007 7:09 pm
im thinking i can build up the area where the arrow is with weld and grind it down smooth so the u-bolt has a better place to grip. lot more work but thats how it goes lol.
but im not sure if that would be as good as some sort of sleeve welded around it either.
no matter what that is where the rear is setting on the leafs fo rsure. i cant move that.
PostPosted: Thu Mar 15, 2007 7:20 pm
forgot to add measurements
frame rails inside are 24 1/4
housing end to end is 42 1/4
that should put me at 47 1/4 axle to axle which is 1 inch shorter than i figured, but isnt a problem.
Users browsing this forum: Baidu [Spider] and 23 guests
