It is currently Mon Mar 23, 2026 4:21 am
what colors would you be interested in powder coating intake manifolds and valve covers
Poll ended at Tue Mar 06, 2007 12:49 am
blue 33%  33%  [ 1 ]
red 33%  33%  [ 1 ]
black 33%  33%  [ 1 ]
yellow 0%  0%  [ 0 ]
white 0%  0%  [ 0 ]
green 0%  0%  [ 0 ]
Total votes : 3
PostPosted: Tue Feb 27, 2007 12:49 am
okay I have an urge to sell some custom stuff on the luv possible not for sure
- powder coated (intake manifolds, valve covers and anything else?)
- grille guards w/ luv lit with led (powder coated or primer?)
- custom louvers (right as of now they are small) have to check with boss as well.
- one shortbed shaved marker lights and or custom work done to it?
- fender flairs possibility?
- turbo kits for G 180 (later on)
just throwing out some ideas seeing if anyone may be interested.
Thanks
James
 Post subject: .
PostPosted: Tue Feb 27, 2007 7:58 am
fender flares would be nice.
Turbo huh?
FIAA: Color Guard
PostPosted: Tue Feb 27, 2007 9:27 am
well the turbo fit on a 2.6 mfi?
80 Luv with 88 trooper running gear 2.6 5sp 4x4
PostPosted: Tue Feb 27, 2007 1:04 pm
Banishment Pending
turbo would be too small for the 2.6, and since it would be for a Luv more than likely a blow through carby setup, 2.6 is MPI, you'd have to figure out how to get extra fuel to the engine when under boost and all that other jazz.
fender flares sound nice, and if it wasn't for the fact that I'm going to be putting in a built 2.6 into my Luv (carb'd not MPI) I'd be interested in the turbo
 Post subject: Turbo
PostPosted: Tue Feb 27, 2007 7:14 pm
TURBO...
PostPosted: Tue Feb 27, 2007 8:37 pm
yeah I am seeing how many are interested in this first
make some kits with small turbo (basically enough to let you go 65 up steep hills on freeways. The reason for a small turbo is less likely to put a load on bearings and parts in engine which could be prone for failure.
no on fuel injection this will be for carb setup.
I am going to do some homework and keep the price relatively low.
PostPosted: Tue Feb 27, 2007 11:22 pm
any pics on the flares you have yet
PostPosted: Wed Feb 28, 2007 8:17 am
If that turbo is a blow through then it WILL work on FI engines too.All you need is a boost referenced fuel pressure regulator and it could be used on a bigger engine but you would have to keep the RPMs down.
PostPosted: Wed Feb 28, 2007 9:07 am
I thought about blow through and draw through set ups but we shall see its on the back burner for now nothing I am currently working on.
Negative on fender flares Ctmandu I am thinking friday I can take some pics
along with stuff for sale
PostPosted: Wed Feb 28, 2007 9:46 am
ok thanks guys i'll do some investagating to see what i can come up with about a turbo 2.6 ok a super charger not sure yet the 2.6 is alto better in the hills then the 1.8 but like i said i'll do some reserch on the matter......:D
PostPosted: Tue Mar 06, 2007 9:27 pm
Okay well I am going to have parts powder coated soon
Timing Chain cover
valve cover
oil pan
maybe intake manifolds
about the fender flares
wont be able to touch them for a week or so kind of busy.
working on it for you guys and girls
Thanks
James
PostPosted: Wed Mar 07, 2007 7:48 pm
LUVTruck.com's Cornholio
I know what I would really really really like for someone to sell is NEW DASHES! :D :D :D :D :D
PostPosted: Wed Mar 07, 2007 9:48 pm
JC Whitney has new dashes for 59.99
http://www.jcwhitney.com/autoparts/Brow ... 64/c-10101
PostPosted: Wed Mar 07, 2007 10:05 pm
those are caps.... not a new dash. they only cover the top
PostPosted: Wed Mar 07, 2007 10:56 pm
well I really dont think I am going to do any dashes a guy could make some box looking dashes out of aluminum. I think dash caps are just fine and do some detail work with some aluminum or paint around guage panels jockey box.
I wouldn't mind later building some dual carb intake manifolds but I have a lot on my plate as we speak one step at a time though folks.
The turbo idea I think I will end up not doing maybe just one or two after I test it of course.
PostPosted: Thu Mar 15, 2007 8:43 am
okay I am going to powder coating place tomorrow so be prepared for some cool parts.
Have pics when they are done
Thanks
James
