It is currently Sat Apr 11, 2026 4:01 pm
 Post subject: Fuel relay
PostPosted: Tue Jan 23, 2007 7:50 pm
well my truck is running not so great
i had my auto's teacher drive it and he said it is most like the fuel relay
and i looked in my haynes and it has nothing
where might this fuel relay be and pics would be help ful
Thank you much
On the search for another Luv Machine
PostPosted: Tue Jan 23, 2007 7:58 pm
Somebody correct me if I'm wrong. I think they are behind that metal cover on the inside of the right fender near the fire wall.
PostPosted: Tue Jan 23, 2007 10:10 pm
Yep...and it was hard as hell for me to find a replacement too.
If you find a place that sells new ones...please let me know.
Mine's good...but I sure could use a spare.
PostPosted: Tue Jan 23, 2007 10:16 pm
It is best to replace the stock one with a bosch style. I can help with the wiring, it is easy.
PostPosted: Tue Jan 23, 2007 10:52 pm
okay thanks guys
i hate my haynes book
it's worthless!
PostPosted: Wed Jan 24, 2007 5:02 pm
Now is this under the hood or what?
cause i duno where it is
<..< dang u luv truck!
PostPosted: Wed Jan 24, 2007 5:44 pm
Under the hood on the passenger fender right in front of the windshield washer bottle.
PostPosted: Wed Jan 24, 2007 6:15 pm
O.o now it's on the passenger side??
PostPosted: Wed Jan 24, 2007 6:47 pm
If the fuel relay only controls the fuel pump. You can run a new wire from a ignition switch (on) source to the pump. Then run a wire from the pump to the oil sending switch. You have to replace the oil sending switch with another switch (got one on my truck but don't know the number of the switch) that switch will be your ground source. It has three prongs on it. One prong you run a wire to a ground. Another prong you plug the oil sending wire on it. It will ground through the wire when the engine is not running. Plug the ground wire from the fuel pump to the other prong and when the engine starts producing oil pressure it switches to the other prong with the pump wire on it to grounding it causing the pump to start pumping.
See the panel in between the windshield washer bottle and my mini truckin sticker on the inner fender, it is under there. Hope that helps, I dont have a better pic of my motor.
PostPosted: Wed Jan 24, 2007 6:53 pm
Very nice and clean engine bay Tilted.
PostPosted: Wed Jan 24, 2007 8:13 pm
okay all is well
drug my GM God over and he showed me where it was
and got a new one at Cheacker after half an hour of telling the guy what i needed.(i even brought it with me)
PostPosted: Wed Jan 24, 2007 10:45 pm
The passenger side is the right side. When talking about any vehicle, right and left are always determined from sitting in the drivers seat. Except for crank shaft rotation. That is determined from standing in front of the vehicle looking at it.
PostPosted: Wed Jan 24, 2007 10:55 pm
sorry was just thinking about it from standing infront of it
BUT now i know
always put urself in the drivers seat
PostPosted: Wed Jan 24, 2007 11:00 pm
:wink:.
Rereading my post I think I sounded a little ... like an ass. :oops:
I didn't mean it that way. I was just trying to help. :wink:
PostPosted: Wed Jan 24, 2007 11:09 pm
It's all good
i don't take stuff to heart
PostPosted: Thu Feb 01, 2007 10:34 pm
does anyone know how to test the fuel pump relay? i am not getting power at my fuel pump. I am also not getting power on my anti dieseling solenoid on the carb. I assume the solenoid should be energized (open) when the ignition is turned on.
thanks
Current Fleet
pics
PostPosted: Fri Feb 02, 2007 3:24 am
The pump only gets power when the key is turned to start or when the motor is running. If you are testing only the key is turned to on without the motor running you won't see any voltage at the fuel pump.
PostPosted: Fri Feb 02, 2007 10:14 am
Thanks 800,
is it the same for the anti dieseling solenoid at the carb also?
Current Fleet
pics
PostPosted: Fri Feb 02, 2007 3:01 pm
i think my relay is bad because the fuelpump is wired around the relay box and im not getting spark at the coil. there are wires going in to the same relay as the fuelpump? what do you tink? is this the same problem?
