It is currently Tue May 26, 2026 12:58 am
 Post subject: how to lower a luv
PostPosted: Sun Dec 31, 2006 6:12 pm
how do you lower the front of a chevy luv.......i am new to these little trucks and don't no much about them...has any one bag and body drop one yet .
PostPosted: Sun Dec 31, 2006 6:36 pm
Swap Specialist Mod
to lower it static, crank the torsions bars in the front, and put blocks in the back.
theres a couple guys on here that have bagged their truck. just ask around.
PostPosted: Sun Dec 31, 2006 8:31 pm
Just be sure to count the number of turns you make on each torsion bar. Otherwise you will never get the truck level again. :lol:
PostPosted: Wed Jan 03, 2007 3:24 pm
does any one have a pic of what to loosen/tighten... i was wanting to raise mine back up cause the roads are way to bumpy and i don't want to tear anything up... it ws lowered when i got it
PostPosted: Fri Jan 05, 2007 6:23 pm
now can i lift my 79 4x4 this way
PostPosted: Fri Jan 05, 2007 6:58 pm
http://i50.photobucket.com/albums/f324/ ... orsion.jpg
Look for these on each side of the trans crossmember. Make sure that the truck is on jackstands to unload the weight. Spray them with WD-40 so they'll turn smoothly. Both 2WD and 4WD trucks adjust the same.
PostPosted: Fri Jan 05, 2007 7:40 pm
dang i sure do love this site
mostly cause u guys know everything
and maybe this will stop my tires from rubing
PostPosted: Fri Jan 05, 2007 7:58 pm
That's right. We know everything and nobody can tell us what to do ever, ever again. 8)
PostPosted: Fri Jan 05, 2007 10:16 pm
Now I heard something about flipping the balljoints is that part of the lowering
Im kind of curious. Not trying to Jack the thread
James
PostPosted: Fri Jan 05, 2007 10:22 pm
i kinda curious where u got the diagram though
those come in handy to have
PostPosted: Fri Jan 05, 2007 11:40 pm
Flipping the ball joints wouldn't work well on a LUV. It would be too much of a hassle to do that kind of mod when loosening the tension on the torsion bars is so easy.
The topic of the torsion bar adjuster came up before and to readily explain what parts were common to it, i drew up a picture showing what was involved. MS Paint comes in pretty handy when you need to draw up stuff. I got a ton of stuff on my truck drawn up to keep track of all the mods done. Axle measurements, wiring diagrams, motor mounts and such.
Click on "Start" / "Programs"/ "Accessories"/ "Paint". Play around with it and you'll see how you can use it to keep a record of your mods.
PostPosted: Fri Jan 05, 2007 11:46 pm
I saw the diagram after I posted. anyways just was curious if it something to be considered. Never hurts to ask
James
PostPosted: Sat Jan 06, 2007 12:08 am
awww see i'm not to good with the drawing stuff out
PostPosted: Sat Jan 06, 2007 12:49 pm
I didn't get along with Paint at first, but after needing to keep track of some wiring mods, i gotserious about learning how to use it. Now i put everything on Paint and it's easy to pull up any info to refresh my memory.
