It is currently Fri Jun 19, 2026 5:10 pm
Post new topic Reply to topic  [ 166 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Thu Mar 30, 2006 5:23 am
800xl wrote:
I've never tried either swap, so I can't say for sure. I'd guess you'd have less trouble on a longbed to longbed swap, just because the length problem would not be as bad.
My idea was to swap an 86ish Trooper rear mount tank in place of the spare tire. It holds more than 20 gals, should close to triple the range if the stock tank was left in place.
Have fun getting rear ended, when I did the bumper went to crap and the "c" part of the frame bent.... the spare tire cushoned the impact
PostPosted: Thu Mar 30, 2006 1:52 pm
Banishment Pending
The Trooper tank can handle the impact, so you wouldn't have to worry about your Luv turning into a Pinto, and if you set it back far enough you shouldn't have a problem.
PostPosted: Thu May 04, 2006 6:15 pm
I noticed that a 72 has the spare tire crank hole on the right side of the bed about 12 inches from the back. I also noticed that the 72 has the 4 way flasher on the e brake bracket.
PostPosted: Thu May 04, 2006 7:53 pm
i remember seeing that hole too... i'll have to spend a little time getting some new info together to revive this thread...
 Post subject: Stepside Fleetside
PostPosted: Sun May 28, 2006 9:44 am
Someone in an earlier post was looking for the drop down, or crank down spare tire holder for underneath the bed on their stepside bed. I had thought that all the stepside beds were aftermarket. Did Chevrolet offer a Luv Truck with a stepside bed?
PostPosted: Mon Jul 03, 2006 2:21 pm
does anyone know the original wheel size and tire size on a 1980 2wd luv?
PostPosted: Mon Jul 03, 2006 11:00 pm
E-78 14b
PostPosted: Tue Jul 04, 2006 12:16 am
Which translates pretty closely to a 195/75R14 in modern metric sizing. I think the wheels are 14x5, but I'm not 100% sure on that width.
PostPosted: Thu Jul 27, 2006 12:01 pm
I've noticed in the Chilton manual for Luvs that changing any of the timing componets, all pictures and detail are of the older engines with the dual timing chain setup, I had someone rework the head on my 80 and they told me the firing order for these engines start from the back, in other words #1 cylinder is at the back(firewall). Is this true?????
PostPosted: Thu Jul 27, 2006 12:34 pm
No... The firing order is 1-3-4-2. If you study the pattern backwards like the machinist says, the order would be the same as 4-2-1-3. This is 180 degrees off.
1-3-4-2-1-3-4-2-1-3-4-2-1-3-4-2
4-2-1-3-4-2-1-3-4-2-1-3-4-2-1-3
A simple swap of plug wires will correct this. As long as the crank and cam are timed correctly to each other.
PostPosted: Fri Aug 04, 2006 4:10 am
Roadshow Bob wrote:
18.5 for the 81/82 longbed
10.0 for the 72/73 trucks
13.2 for all the rest
Well, looks like we're both wrong roadshow, i found out the hard way that the tank in my 84 auto L/B is a 13.2 i think... lets just say i found out "the hard way" that it wasn't... BTW, it's a diesel so maybe that has something to do with it?
PostPosted: Fri Aug 04, 2006 10:42 am
that very well could be, my manuals don't have the specs for diesels :oops:
PostPosted: Sat Sep 02, 2006 10:50 am
I just got a manual trans. from a 77 and learned that the hydraulic clutch set up has the T O bearing fork on the right side of the bell housing.
My cable clutch set ups in my 78 and 80 have the fork on the left of the bell housing.
Anybody else ever noticed this?
PostPosted: Tue Nov 28, 2006 11:18 pm
Today is very cold, 21°F @8:56 PM, but earlier in the day I put on the sun visors that I got yesterday. I got a matched pair off a '72. I was surprised to find they came with a center hookup that screws up with the mirror mount. The original sunvisor on my '78 just hung from the swivel bracket and had no center accomodation.
It seems this is a very relevant bit of information to anyone who might want to make their LUV better. I can't say whether this was just an option or not.
Sorry, no pics today. I can't get in the door 'cause it's frozen. I should've done it earler today. Later, I promise.
Image Image
Photo added on December 22. 2006
'78 1.8L 4-speed Fleetside
Image Image
 Post subject: My Australian Luv Specs
PostPosted: Sun May 27, 2007 5:11 am
Australian LUV Guru
1980 Luv 4x4
c190 1951cc (119cu.in) 20:1 DIESEL Engine
4 speed transmission
4.555:1 ratio differentials
Disk brake front, self ajusting rear drums
13.2 gallon fuel tank
4 1/2 x 14 rims
I have also have two 5.125:1 ratio third members removed from 2wd pre crossflow engined LUV's
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Mon Aug 27, 2007 9:40 pm
what were the main colors cuz most of the origional paint iv seen are ugly like the light blue the first day i got mine i sanded it all off i felt like a little farie drivin that around but now its still not done n its been almost 1 year :(
PostPosted: Fri Dec 14, 2007 11:43 pm
the best place for any year modle is a compeny called MSX they have these things called resto kits their # is its all free all you need is you make year modle and vin# i have got severl for my luv trucks and my 72 elcamino on the luvs what i have is for serise 5 (1976) it gives all of the dimensions of the body weights tires sizes all exterior fetures mikado incloded it talkes about the cab construction the same for the bed all of the standard specifications for engine front and rear susuension the breaks the electrical frame fule tank steering transmission and lots more it has a colors chart for the interior and exterior a price list with all of the options listed with weight of each and prices if someone gets one of these ordered for each year modle and puts it on this site we can all know for shure what came on what year modle and what someone has changed over the past years i will try to get all of the stuff i have posted as soon as i have the free time just this resto packet is 7 pages long plus i have a lot of old ads i have found and more info than i could ever type out everone plese call this number 1-800-222-1020 and get one of these packets so we can get it all strighten out
PostPosted: Wed Jul 02, 2008 4:27 am
years 72 -80 didnt need a cat, 81 and up does
~M
PostPosted: Wed Jul 02, 2008 8:52 am
Incorrect, they started putting them on in 1976 as per the Chevy parts manual.
PostPosted: Fri Jul 04, 2008 11:56 am
ok well i am probley wrong, but as far as emmisions in arizona is concerned i dont have to have a cat on this truck if its a 80 but a 81 i do.
~M
Users browsing this forum: Baidu [Spider], Google [Bot] and 76 guests
