It is currently Tue May 26, 2026 8:39 am
 Post subject: air pump removal
PostPosted: Sat Nov 11, 2006 5:04 pm
I am taking my generator off to have it checked . my battery is undercharging. according to my manual i have to re the air pump first which i assume is part of the emissions system. here in WA because of its age it doesnt have to have an emissions test.Can i leave it off
of course it hurts you are being screwed by an elephant
 Post subject: Smog pump
PostPosted: Sat Nov 11, 2006 10:31 pm
I haven't been running the smog pump on my '80 for 3 years now. Hasn't seemed to hurt a thing.
PostPosted: Sat Nov 11, 2006 10:37 pm
You'll need to cap off all the lines to the carb, intake and air injection reaction. You can keep the e.g.r. valve in place and either cap off the vacuum line to it or leave it functioning. Leave the p.c.v. system alone.
You'll lose some gas mileage with the smog pump eliminated but nobody really complains about it.
PostPosted: Wed Nov 22, 2006 1:26 pm
do you really think you will loose mileage? I thought you might gain some milage since you are not having to drive the smog pump anymore.... although I have never tested the theory
Current Fleet
pics
PostPosted: Wed Nov 22, 2006 2:40 pm
LEAVE IT OFF!!!!!!
I brought my '80 home and that was the first thing I piched in the garbage!!!!!
all it does is pump fresh air into the exhaust to make the emmisions machine "think" that the exhaust is leaner.
GET RID OF IT IF YOU CAN!!!! Probably gain about 5 h.p.
My $ .02
"If at first you don't succeed you're doin' it wrong"
PostPosted: Wed Nov 22, 2006 2:42 pm
The smog pump basicly handles 2 different concepts. 1st, it provides forced air to the air injection reaction system. This system will reduce the hydrocarbons by pumping cold air to the exhaust ports. This causes an explosion which burns off more exhausts. 2nd, the smog pump provides forced air into the intake manifold thru the mixture control valve. Under decelleration, the throttle plates close which creates high manifold vacuum. Since the motor cant pull air into the engine, it will pull fuel thru the idle circuit of the carb. The mixture control valve will open during this condition and the manifold vacuum will be reduced. The lower the manifold vacuum, the less the motor can pull fuel thru the carb. This reduces the amount of spent fuel.
Removing the smog pump will reduce the amount of parasitic drag on the motor but that gain will not compensate for the fuel waste.
If you filled the tank and hit the Hwy and drove until you ran the tank low, There would be a slight chance of gaining mileage. But in normal day to day driving to work, Walmart and the parts store, you'll notice a loss in mileage.
The reason to keep the e.g.r. and p.c.v. systems is because the e.g.r. will reduce combustion temperature and it can be a pain in the ass to remove and cap off.
The p.c.v. system will help keep the engine oil cleaner, longer. Pulling crankcase vapor and blow by into the intake to be burned, blow by and vapor doesn't build up in the crankcase to blend with the oil. With the positive pressure fuel system of the LUV, excess fuel tank pressure is dumped into the crankcase. The p.c.v. system will allow the vapor to be burned.
As for running without a smog pump, if your state doesn't test for it, get rid of it. I saw it as a major source for potential air leaks. Mileage loss is quickly overlooked when you have a smooth running motor.
PostPosted: Wed Nov 22, 2006 6:33 pm
The smog pump doesn't take much power to run(2-3) in good condition but they are a damn pain in the butt and in the way same as the EGR if you don't have to worry about the smog patrol the loose the junk and tune the motor you will find that it will run allot better.And do not through the stuff in the garbage cause there are people on the web site who could use the stuff.
PostPosted: Wed Nov 22, 2006 11:28 pm
good looking out tjwhite
PostPosted: Sat Dec 09, 2006 2:12 am
where can i find the plugs to match up with the holes in the block? or what should i use?
PostPosted: Sat Dec 09, 2006 4:13 pm
the threads to plug the holes are hard to find. it is 14mmx1.25 pitch. These threads are actually the same as 14mm spark plug thread.
the only other thing I could find was a oil drain plug that seams to be for a for diesel that has the same threads. although a couple of the cylinders do not seen to have a nice flat surface for the drain plug to seal.
the other options I have heard of is cutting and sealing the stock air injectors. either by crimping the tube, tapping and inserting a bolt or welding it shut.
my current truck I have left the stock air injector rail and caped it off behind the check valve.
Current Fleet
pics
Users browsing this forum: Bing [Bot] and 73 guests
