It is currently Sun Apr 05, 2026 12:51 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 328 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 17  Next
PostPosted: Sun Oct 29, 2006 12:59 pm
Almost Missed That, Sorry RPOZ11
Yeah I'll Take A Few More Pics Than Buckle everything Back Down and Measure
I've Actually Bolted My Fenders On and Eyeballed Everything and The Fit What Appears To Be Pretty Darn Close To The Stock Location With a Set Of Older Model Camaro Wheels They Fit In The Finderwells Just Fine
No Go-Cart Appearing Wheel Abstruction Here
I Have Came Accross One Prob The Only Way To Use A 92 and Up Camaro Style Wheel Is To Run A 17.
The 92 and Up 16 Have A 6 Inch back Spacing And Rub The Upper Control Arm
The 17 Are Tall Enought To Clear Even Though They Have A 6-6.25" Back Spacing
However If You Go With A 17" Wheel I Suggest A 8" Instead Of The 9.5" Wide Wheel Because Clearrances Are TIGHT!
BUT THIS IS WITH STOCK SPINDLES! Please Note That Most Problems Should Be Fix With 2" Drop Spindles Because It Will Raise The Center Point Of The Hub
But Older Model Camaro/S10 Wheels Do Just Fine With No Additional Problems ( I Think Most of Them Have A 4-4.5" Back Spacing ) Plus These Year Model Wheels Are More Common And Normally Alot Cheaper
Or You Can Go old School, Skinnyz Work Perfict!
PostPosted: Sun Oct 29, 2006 7:00 pm
So you run a ranger rotor on an s-10 spindle?
PostPosted: Sun Oct 29, 2006 10:00 pm
Am I looking at your pictures right, the lower ball joint is bolted to the bottom of the lower a arm, if so do you trust all of the weight of the front on that small of a flange with 3 bolts under slung?
PostPosted: Sun Oct 29, 2006 10:07 pm
Looks like 4 bolts and 1/2 " plate . Looks like I'm shopping for s-10 junk now
PostPosted: Sun Oct 29, 2006 10:40 pm
LUVRV8
I considered that as well!
Made me think that making a lower control arm specifically for that ball joint/spindle app would resolve this....
just my thoughts though.
PostPosted: Mon Oct 30, 2006 3:01 am
Good Point
and I Have Thought Of That
I Actually Thought About Cutting The Lower Control Arm and Making One Out Of Square Tubing, But This Idea Came To Me After Replacing Ball Joints On A 93 S10
Look At A Factory Ball Joint, Little Thicker Then A 1/4" and Its Cast Steel
What I Use Was The Highest Rated Steel In Our Towns Metal Shop
And All Bolts Where Just Use For Mock Up But There Grade 8 Chevy Head Bolts
and Additionally S10 Ball Joints Are The Same Part Number As Most Of Your Older Camaro/Trans Ams, Most Cars Weighing Around 3600 lbs.
Not To Forget A Good Number Of These Cars Where Big Block
They Worked For Chevy For Years, Might as Well Use What You Know Is A Good Product
BTW Them Are S10 Rotors, But Yes A Ranger in The Late 80's Early 90's Has The Same Inner Bearing, The Outer Are Different Because Of Hub Size
Oh One More Thing I'll Post More Pic Tomorrow Including Additional Pics as Requested Of The Lower Control Arm, Part Numbers, and Adapter Plats
PostPosted: Mon Oct 30, 2006 3:08 am
I Actually Believe It Will Hold Up
I Wouldn't Have Posted My Idea If I Thought It Would Get Someone Hurt
I Just Knew The Lower Ball Joint Wouldn't Work Up Side Down
I Also Knew That The Upper One Off A S10 Would Work (Direct Bolt In Almost) I Have Seen and Help Put Them Into Use W/ Factory Spindles
I Look At It This Way, The Old Rule Of Hot Roding When Something Like This Holds You Up When You Are So Close, Fabricate and Make It Work
PostPosted: Mon Oct 30, 2006 10:48 am
Being a mechanic and race car fabricator I would have to look at this closely in person before I would ride in that truck.
PostPosted: Mon Oct 30, 2006 5:21 pm
1/2 " plate is way stronger than that ball joint ever hoped to be. Is your concern that it might bend?
PostPosted: Mon Oct 30, 2006 5:30 pm
I have several concerns. First is a under slung ball joint. Second is the drilling of the a arm, it weakens it and if you weld it it could weaken it more, heat will even turn chrome moly into mild steel. And the last worry I have that if you over build with too thick of metal it could cause a nother part to fail, like if it is too strong and sends the forces to other parts that were not designed for it.
It is his project so if he feels it is good then he can have it, I would rather spend the extra few bucks to get a well engineered product. I love when people come here with cheap and un proven ideas with brakes and talk about spending a grip of money on a engine. Wouldn't it be better to have a set of good brakes to stop the H.P.??
PostPosted: Wed Nov 01, 2006 12:13 am
I Didn't Drill The Control Arm I Used The Factory Bold Holes. Secondly I've Been Working On Suspension Components For Close To Nine Or Ten Years. So I'm Not Just Jumping In Here And Saying This Will Work All While Wearing A Blind Fold, As I've Once Have Already Said I Wouldn't Have Posted This Idea If I Thought It Would Get Someone Hurt. Just Think The Lower Control Arm Of A S10 Is Thin Stamped Steel, The One On The LUV Is I Beamed Design W/ Reinforced Bolt Holes. Might I Add A Blazer ( Which Is What The Spindles Came Off From ) Weighs In At A What, Near 4000 lbs., And A Luv Soaking Wet Weighs What 3000 lbs.The 1/2 Holes Where Drilled W/ A Diamond Tip Bit Witch Cut Through It Like A Knife Through Butter, The 2" Hole Was Cut With A Layth. So Very Little Heat Comes Into Play. The Same Amount Of Weight That Would Be On Top Of The Control Of Is Still There, Just On Bottom. I've Also Left Plenty Of Extra Steel To Brace Itself On The Lower Control Arm. The Upper Control Arm Was Basically Untouched. The Closest Thing To Being Dangerous On This Project Would Be When I Smooth The Edges On The Spindle, Which They Was Way Less Than An Eighth Of An Inch Taken From It. If You Want To See It Up Close Come On Over, Or Wait A Day Or So And I Will Post Closer More Detailed Photos Of The Object Under Discussion.
PostPosted: Wed Nov 01, 2006 12:34 am
I personally like the idea
http://myspace-654.vo.llnwd.net/01351/4 ... 7654_l.jpg
IMHO seems heavy duty to me , but i'll probably run aerospace system .
PostPosted: Wed Nov 01, 2006 12:46 am
The Passenger Side Looks Better, LOL Dunno Why I Didn't Post A Pic Of It.
Gotta Back Side Pic Though
http://i134.photobucket.com/albums/q106 ... 010304.jpg
I Have No Clue Why I Am Just Now Posting It.
I Actually Have More Pics I Need To Post
I Will Post Them All Tomorrow W/ More Pics To Show Everything On The Suspension.
Also Doesn't A S10 Front Caliper Have A Greater Clamping Force Than A LUV
( Looks Like It Should )
PostPosted: Wed Nov 01, 2006 12:47 am
Swap Specialist Mod
ok, what did you do to the lower control arm to make it "Y" shaped at the end? like in this pic...
now if you were to make a CAD drawing of the lower ball joint mount. so i could have a pair made, id defianantly do this to my luv.
PostPosted: Wed Nov 01, 2006 12:54 am
Hmmmm.....
I Will See What I Can Do Joe
PostPosted: Wed Nov 01, 2006 12:58 am
Swap Specialist Mod
i still dont understnad what you did to the lower contol arm. did you take 1 larger piecut out of the center, or did you do 1 cut donw the center, and then pie cut the 2 sides and bend them out?
PostPosted: Wed Nov 01, 2006 1:05 am
LOL Again I Need To Take A Pic Of The Passenger Side...I Haven't Clearance That Side At The Time The Pic Was Taken, I Just Slightly Smooth The 2 Hard Edges. There Is My White Paint For Where I Made My First Template That You Will Also See On The Other Side, I Know I Will, Tomorrow Pix Galore Of The Suspension, Brakes, And My Truck
Maybe Even My Car For The Fun Of Things..lol For Hotrod80 Ya Know, He Seems To Like It
PostPosted: Wed Nov 01, 2006 1:08 am
Swap Specialist Mod
so is how your LCA is right now what a stock bottom looks like. you didnt cut it or anything?
PostPosted: Wed Nov 01, 2006 1:14 am
Yup sept basically the plat for the ball joint is home made not Isuzu and the plate is relocated to the bottom as well all know by now, instead of the top.
Plus the inside of the pie (lol) is smoothed :lol: off
PostPosted: Wed Nov 01, 2006 1:19 am
Swap Specialist Mod
well shit, if i ever v8 my truck, or just wanna get a set of cragars on that damn thing ill have to do it this way!!
