It is currently Tue May 26, 2026 3:25 am
 Post subject: quarter mile gears
PostPosted: Thu Oct 12, 2006 3:25 pm
Location: Colonial Beach VA. If i am not home or at the track then I am probably at HOOTERS!
:roll: i any one aout ther runing 26'' tires in the quarter? i run 26s and 4.30s and am not sure weather or not i can make the quarter i want to try but hate to waste time and fuel to get there if i can t make it thanks!!!!!
PostPosted: Thu Oct 12, 2006 8:13 pm
I used to run a malibu with 4:56's and 26 inch tires. It worked out even with the spray. It will depend on your combo, but it should work.
PostPosted: Fri Oct 13, 2006 6:30 am
It all depends on what RPM you want to run you engine at.
PostPosted: Sat Oct 14, 2006 1:13 pm
I have 26'' tires with 4:30 gears. I usally run about 7200 to 7400 in the quarter with a 383 on the bottle. Depending on the combo it it really just a guess.
PostPosted: Wed Oct 25, 2006 9:27 am
I have a 26" tire 475 hp motor and I run a 3.50 . A buddy of mine has a chevelle 400 hp 400 shot of dope , runs 9.94 with a 3.42 . He runs that cheap street class.
PostPosted: Mon Nov 06, 2006 9:56 pm
how high do you rev your motor?!?
there are calculators all over the internet that will help give you an idea on what you need... just type in your tire height and gears.. just depends on how high you wrap that engine!
!!!FINALLY!!!
-1977 Luv mikado
