It is currently Sun Mar 22, 2026 5:32 pm
Post new topic Reply to topic  [ 364 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 19  Next
PostPosted: Sun Aug 27, 2006 4:08 pm
that is a work of art man. 8)
PostPosted: Sun Aug 27, 2006 10:47 pm
hotrod80 wrote:
todays picture
OH boy... look at the fingernails clearence between the pulley and radiator. Could it get any closer?
Could I get you to take a picture of what you did to secure the radiator to the framework of the truck? My radiator should be in this week and I need to start fabbing something.
Thanks in advance.
PostPosted: Mon Aug 28, 2006 9:29 am
Farmer thats a factory mount extended to the length I needed and braced up to support . If you look close in the pic you can see a cross threaded bolt on top of the cross member , that has been corrected also.
Luvondope looking forward to checking your street out, or any street for that matter . It's hard to stay at a slow pace and keep the quality of my work up.
mepr thanks for the compliment .
hyperwrx I'll try and post the requested pics . There is actually more room then the picture shows . I have a spal pusher in front of the radiator , but have a thinner steel water pump pulley and flex fan that will fit if I decide to go that way later . Remeber that is a thick aluminum pulley with countersunk allen bolts . The origanal plan was to get the air conditioning functional again . My wife is pretty understanding about my projects , but it's easier to spend if she hears it run or I drive it .
PostPosted: Mon Aug 28, 2006 9:41 pm
I'm so ready to fire this thing off it's killing me . It's got 255/60/15 road huggers on back for break in . Then we go to 235/60/15 et street radials and the drag strip . The time slips will folloew the passes with the tune tips .
PostPosted: Mon Aug 28, 2006 9:47 pm
Swap Specialist Mod
you better get some videos of this machine!! :D
PostPosted: Mon Aug 28, 2006 9:54 pm
Still hoping for those radiator pictures!
PostPosted: Tue Aug 29, 2006 10:47 am
Radiator pics
In this one you can see where i cut back to the support and bent it in a s shape at the bottom. fuel hose is used to isolate rad from support. You can also see the bottom angle brackets that keep the bottom of the radiator in place . I should really paint that nasty battery tray.
This is the front side , again fuel hose , I have more room to cut to move the bottom of the radiator toward the grill , but will only do that if I run a fan on the water pump.
This is the gap between the radiator and the pulley . Also shows top radiator mount . A peice of angle iron bolted to support and then self tapping screwed to top of radiator flange . More fuel hose .
PostPosted: Tue Aug 29, 2006 1:14 pm
hotrod80: thank you very much
PostPosted: Thu Aug 31, 2006 10:03 am
found one more
PostPosted: Thu Aug 31, 2006 10:09 am
Swap Specialist Mod
that last pic looks familiar... lol
lee did damn near the same thing
PostPosted: Thu Aug 31, 2006 10:07 pm
Latest pic , and i have the same overflow bottle except blue and minus the advertisment.
PostPosted: Fri Sep 01, 2006 12:06 am
Swap Specialist Mod
boy that truck looks familiar. did you buy it from someone on here?
PostPosted: Fri Sep 01, 2006 9:17 am
The truck originally came from oklahoma . I bought it off ebay in January . It was "already set up for a small block" . Which means we pulled a perfectly good 56,000 mile 4 cylinder and threw it away. Here is the day I rolled it off the trailer. If it would have had the original motor in it I would have never taken it out .
PostPosted: Thu Sep 28, 2006 9:20 pm
Well, it's been a while, My neck has not been good , explosion at work , low on money , ETC. It's now in muffler jail . Check it out.
Anyway We should finish up tommorow , I will follow up with pics . I still have to have a driveshaft built . Been working on thinks for a week and a half and it does not look like i've done anything . I'tll get there eventually.
PostPosted: Thu Sep 28, 2006 9:25 pm
Muffler looks nice.
Question- I have to do my driveshaft also. What are you using for your base shaft to work from?
I am thinking about 2nd gen camero for starters and think I will have to have it shortened a bit due to my v8 sitting back a little bit.
PostPosted: Thu Sep 28, 2006 11:30 pm
those motor mounts are the same design as mine.. the only difference is mine are all 3 peices of round tubing!
that is awesome!
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Fri Sep 29, 2006 7:41 am
I had the front part of a 2nd gen Camaro shaft cut off with a torch and the rear part of a truck shaft cut off . When I take it to the driveline shop , all they have to do is cut a peice of tube and balance it . The yokes can get expensive . Some shops willeven trade you or give you credit for your old parts. You can see the cut off shaft in the picture to keep it from loosing tranny fluid . Man I need a winch on my trailer.
PostPosted: Fri Sep 29, 2006 11:32 am
thanks
PostPosted: Fri Sep 29, 2006 7:01 pm
Well , I got it out of the muffler shop , but was running late and had to work tonight . I'll post try to post pics tommorrow . 10.4 to 1 compression is hard to keep quiet . It is set up so I can pull the muffler and go open headers . I have a tranny leak at the dipstick and a collent leak at the heater valve . :oops:
PostPosted: Fri Sep 29, 2006 7:25 pm
let's hear it.
