It is currently Mon Jun 08, 2026 11:14 am
 Post subject: random backfires
PostPosted: Thu Jul 13, 2006 5:59 pm
well i have a problem. i just got done rebuilding my engine. i put it together, it's timed properly, and it backfires. about every 15 seconds. it's got new points. new wires new plugs. i haven't timed it with a light yet but it runs fine where i've got it accept for the backfires and a lack of power. i'm getting a timing light tomorrow. but i don't think that will help. could it be my vac advance? i'm at a los. help!
1980 luv 1.8 finally running!!!...... and then like a moron i sold it :(
got another one!!! 1980 mikado. v8 swap here we come... nope divorce and cross country move happened.
got another one!!! 1980 4x4 mikado sport. rusty beater for now...
PostPosted: Thu Jul 13, 2006 6:30 pm
Is it backfiring out of the exhaust or the carb?
PostPosted: Thu Jul 13, 2006 6:33 pm
the carb. but not huge backfires just a little bit and if i try to drive it it lacks alot of power. and it backfires more.
PostPosted: Fri Jul 14, 2006 5:03 pm
well i guess nobody has any idea's so i guess i'll just try putting this thing in there Image
PostPosted: Fri Jul 14, 2006 5:36 pm
If your talking about putting in that electronic distributor You will need a cap for it. The older cap wont work and when you get it watch out for the firing order on the new cap it shows a rotating the opposite of the old one. Keep the wires on the old one and transfer them to match. The 2 and 3 are reversed.
PostPosted: Fri Jul 14, 2006 6:32 pm
What is your advance set at?
Did you do a lean idle adjustment?
PostPosted: Fri Jul 14, 2006 9:38 pm
how do you do a lean idle adjustment? and i don't remember what i set the timing at i think it was 6 degrees b-tdc i'm not sure i check again though. i've tried changing it but it does the same thing.[/quote]
 Post subject: Been there; Done that
PostPosted: Fri Jul 14, 2006 10:49 pm
You said lack of power, and I bet when you get on it hard the backfiring gets even worse.
I've driven 5 miles this way after a rebuild once since the engine seems to do okay at idle.
The wires for 2 & 3 are probably swapped now.
-DK
PostPosted: Fri Jul 14, 2006 10:52 pm
Yeah, I think 6btdc is book. That's a good place to start. You had the distributor disconnected when you set it, right?
Someone else here (and I apologize I don't remember the author) had a post about running the engine up to 3000 rpm, and then setting it for about 30 degrees with an advance timing light. I just tried that yesterday. I was about 6 to begin with, and now I think I'm about 9 btdc.
As for lean idle, each carb has a sequence to go thru. My truck still had a cherry decal on the inside of the hood for instructions. That went out the window when I got the Weber, cause it has it's own instructions. The tech manual will give you an idea of what you should be shooting for.
It's what is says it is--"lean" idle. Basically, (and I mean basically) you turn the idle mixture screw in until the engine starts to die, and then back it out until you get a smooth idle. Then, you fine tune the idle with the idle adjustment screw.
Keep us posted--
PostPosted: Fri Jul 14, 2006 11:24 pm
firing order clock wise 1342 right? if so it's not the wires. and i noticed today that it ran ok when it was cold and didn't start sputtering until it warmed up. maybe it is running too rich at idle. :? i'll check the timing again monday. i gotta work this weekend :cry:
PostPosted: Sat Jul 15, 2006 12:56 pm
The firing order is right, b-u-u-t, I thought it was counter clockwise. Now you've got me curious. I'll have to go kick the engine over and see.
PostPosted: Sat Jul 15, 2006 10:47 pm
hmmm that would put my 2 and 3 backwords and the 1 and 4 would still be right. i'll have to check that monday
PostPosted: Sun Jul 16, 2006 5:05 pm
counter clockwise
PostPosted: Mon Jul 17, 2006 8:17 pm
well i got it figured out but now she's running really rich. but it did that before. i think the idle richer thingy is stuck at richer or something. thanks for all your help. i feal really dumb. it wasn't the 2&3 but the 1 and 4 were backwords. man i'm a moron. :roll: :oops:
Users browsing this forum: Bing [Bot], Google [Bot] and 41 guests
