It is currently Mon Jun 08, 2026 11:15 am
 Post subject: fuse blowing
PostPosted: Sat May 13, 2006 5:35 pm
well my buddy has my old luv which i intend to get back
but the problem is the starter went out and i help putting a starter from a parts truck in it then it worked for a while and now wont start have to push start
and the regulator fuse keeps blowing something to do with the alternator
he replaced the battery cables not to long ago so i cant think of what it is off the top of my head
thanks in advance
James
PostPosted: Sat May 13, 2006 6:10 pm
Will the truck keep running at idle when you get it started or do you have to gas it up to keep it running.If it quits at idle check your voltage regulator.
PostPosted: Sat May 13, 2006 7:04 pm
it has built in voltage regulator they told me it will run once started then it will blow a fuse while driving supposively killing the engine
i tossed the idea of external voltage reg. after i went through 3 of them in a short period of time
PostPosted: Tue May 23, 2006 3:20 pm
you might check and see if starter has shims and if it does and you didn't put back correct it will make starter go bad
Users browsing this forum: Bing [Bot], Google [Bot] and 38 guests
