It is currently Fri May 08, 2026 9:52 am
 Post subject: i have a crazy idea
PostPosted: Wed May 10, 2006 12:54 am
hay i know i've ben gone a wile but my time spent away gave me a wicked idea for a complealy insanely unnoticeable custom job for the 78 long bed
i was thinking
if i cut the window frames off the doors, split then and weld them to the cab and re wether strip them i would have convertible style doors right
well it not that insane but a neat idea
oh i was wondering if anyone ever dropped a 454 out of a 71 ss elcamino in a luv before cause i got one i'm the shop in huchison and i'm wanting to see wat that baby can do in a light body
my frends dodge says its eaten chevys and shiting fords well i say AT LEAST ITS EATING SOMETHIMG GOOD
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Wed May 10, 2006 1:32 am
By splitting the window frame, i assume you're saying that you'll separate the the track channel. If so, will you scrap the outside edge to allow the glass to stay up when the door is opened and closed? It could look odd because the original glass will have a noticable gap all around. And the headache of trying to seal the glass to weather stripping.
The original design of the window calls for perimeter reinforcement. The frame is also a guide to keep the window squared up as it moves up and down. It may not be worth trying to reinforce the window track inside the door to hold the glass solidly.
Plus the fact that LUVs aren't know for being the most burglar-proof trucks, it will be that much easier to snake a coat hanger between the glass and weather strip.
As for the big block, lots of trucks have been modded to fit. The firewall will need to be worked heavily to make room and also the trans tunnel. The gas and brake pedal assy's will need to be shifted off the left because of the firewall/trans tunnel mods.
Get ahold of RATINLUV, you can see what he's done to his LUV.
PostPosted: Fri May 12, 2006 2:43 am
thanks i got some old beat up doors i try it with first and as for the burglars
i'm not to worried with the kick ass viper alarm system i just had put in
oh has any one poped a 1977 fiat spider 1800 twin cam motor in a luv cause i got one and it looks like it bolt right up with some fab work
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Fri May 12, 2006 10:16 am
alot can bolt up with a little Fab work :twisted:
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Fri May 12, 2006 7:39 pm
No offense but I dont understand the purpose of doing that if you arent going to make it a convertable, all you are going to do is make your truck noisier and wetter on the inside of the cab. I'm all for the big block though!!
PostPosted: Sat May 13, 2006 9:46 pm
well i thought the convert doors would be really cool lookin and i never roll up the wndos aney ways
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Sat May 13, 2006 10:15 pm
Fitting a big block in the truck would catch the eye of a thief. Even just to joy ride a hot rod truck. Having reworked windows that dont provide much security would almost be an invitation.
As for me, i've let it be known to too many people that i got a V-8 under the hood and im very leary of having my truck taken.
Users browsing this forum: Bing [Bot] and 17 guests
