It is currently Mon Jun 08, 2026 12:02 pm
 Post subject: Pulling power
PostPosted: Wed May 03, 2006 9:19 pm
I know a stock 4x4 luv has like 90 torck but what is the wight limet for one to tow a trailer of some sort
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Wed May 03, 2006 9:42 pm
I dont think tongue weight would be but a couple hundred pounds unless you beef up the rear shocks, as far as what you can pull weight wise, I recommend not pulling anything heavier then your truck :lol: :lol: :lol:
PostPosted: Wed May 03, 2006 9:48 pm
We kinda covered this with you a few months ago. The stock LUV can pull a fair amount of weight, but stopping is a concern unless you have trailer brakes.
torck????????????????????????????????????????????
PostPosted: Wed May 03, 2006 9:49 pm
I know the suspison can handel my boat but like pulling power like the max for the motor
My bad my spelling sucks
79 4x4 1.8 liter
PostPosted: Wed May 03, 2006 10:08 pm
how big is your boat?
mine is a 14 foot aluminum boat and my 80 luv pulled it with the stock motor in it
80 Luv with 88 trooper running gear 2.6 5sp 4x4
PostPosted: Wed May 03, 2006 10:36 pm
i have pulled around 7,000lbs with my LUV before. But that was for a block or two and the other truck was on a strap with my buddy driving it. I also had to use my transfercase as a range splitter...
PostPosted: Thu May 04, 2006 12:55 am
Swap Specialist Mod
i just had 1200lbs of scrap metal in the pup the other day, and it handled it fine. well going and stopping wise. it was riding on the axle the whole time. it was damn low though. it looked sweet!!
but yeah, with the 1200lbs in it it just felt like it had the old motor in it.
on another note, me and TR tow barred the schools race car (3200lb 78 olds cutlass) out to the track last sunday with his 79 4x4, and it did it awsomely. we did 60 the whole way there. there was on spot where he used the transfer case as a splitter, but that was a start on an overpass incline.
PostPosted: Thu May 04, 2006 5:48 am
I have towbared other LUVs with mine before and it was fine. I wouldnt tow much more than2500lbs unless you realy know what your doing though.
PostPosted: Thu May 04, 2006 9:49 am
My boat is 17 foot I think the only problem I will have will be stoping
I want to see how much the boat wighs just I know if I can go long distance like up the mountains
79 4x4 1.8 liter
PostPosted: Thu May 04, 2006 9:11 pm
it should pull it it will be a little slower on the hills is all
