It is currently Fri May 01, 2026 4:48 pm
 Post subject: Block heater 0-ring
PostPosted: Fri Apr 07, 2006 8:48 pm
One item I have not been 100% sucessful in finding is the proper size o-ring for the block heater. The one I am using now is from the local Caterpillar dealer. They have a nice selection of o-rings and I found one close although it does fit tight. Also any ideas on the sealing of the small retainer screw in the middle?
PostPosted: Tue Apr 18, 2006 7:53 am
I have found a large selection of O rings at Ace Hardware or Home Depot. Though I have never had a problem with the screw leaking on my block heaters, if one was to do so I would seal it with Permatex high temp RTV, the red stuff, (after removing and cleaning the heater).
PostPosted: Fri Apr 21, 2006 9:52 pm
Thanks for the reply. The O-ring would need to be able to take not only the temprature of the engine, but also the block heater itself.
PostPosted: Sat Apr 22, 2006 11:33 am
The engine block is not very hot where the plug is (relatively speaking) as the water jacket is right there. The brass plug and O ring should never get hotter than the temp of the coolant which is flowing through rubber hoses.
PostPosted: Sat Apr 22, 2006 4:57 pm
Why don't you just buy a new block heater? I find the stock ones break too easy.
PostPosted: Sat Apr 22, 2006 9:46 pm
Second time I have heard that suggestion, I give! Next time I will go buy a new one. :?
PostPosted: Sat Apr 22, 2006 9:58 pm
I have had one on back order from NAPA for 40 some days. Keep the old one for a spare.
