It is currently Tue May 19, 2026 4:56 pm
Post new topic Reply to topic  [ 303 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 16  Next
PostPosted: Wed Feb 15, 2006 8:13 pm
rezkid wrote:
They did, but they don't make it any more. you might still be able to get an Aussie locker for it.
215x75r15's seem to be the tire of choice for us 4x4 guys, I'm running them, but in the BFG A/T KO flavor :twisted:
Yea, they should remake the posi kit. They'd get plenty of customers off this site.
Since I went to the bigger tire, my spare is the same size and I cant put under the bed since it will be to close to the exhaust. I'll have to wait
till I can modify it, for now its the back of the bed. :D
PostPosted: Wed Feb 15, 2006 9:15 pm
215x75R15s or 235x75R15s are a good choice. I've run both those sizes, and my favorite thing about them was LT rated tires available in A LOT more tread patterns.
Right now I've got 215s on, no body lift, little no suspension lift (prior owner could have done a couple turns on the torsions) and I don't rub unless I'm crawling across deep ruts. Stock 86 Trooper steel wheels. It is close though, 235s would probably hit fairly often even on the same wheel.
I've got some 215s on wider wheels with less back spacing, they hit sitting still just turning the steering wheel. It just takes the right wheel so they tuck in nicely.
PostPosted: Wed Feb 15, 2006 9:25 pm
Banishment Pending
The 215's I have now did rub a little at full lock, but after I did the t-bar crank I got rid of that problem. I'm looking to maybe get some Isuzu "Snowflakes" which are 15x7 w/ i believe a neutral offset. some 235's on them and they'd look pretty darn good.
PostPosted: Thu Feb 16, 2006 5:54 am
Tea Kettle wrote:
wow must be a lot of trails up der in Spokane
Not as many as you would think. We travel ALOT. In 4years time i have put over 100,000miles on my truck, and i have sleeping in the cab down to a science... 8)
PostPosted: Thu Feb 16, 2006 10:48 am
Banishment Pending
sounds like you need a kamper :lol:
 Post subject: Snow Luv
PostPosted: Sat Feb 18, 2006 10:36 am
Last night it snowed here. I only live at 2000 feet elevation. But I' decided to take more pics.
Maybe all the snow in the bed will help me get better traction. :lol:
PostPosted: Sat Feb 18, 2006 10:46 am
Oh Zane, aren't you lucky. My dad lives in Grass Valley. I just love it up there. We were planing to move up there somewhere in 4 years, after my youngest graduated, but now I have this new job that would be stupid to leave. So I guess we are here until retirement age.
PostPosted: Sat Feb 18, 2006 11:01 am
Its nice area if you like the outdoors. Funny you mention your job, I'm working at getting a 3D graphics job, meaning I'll be moving away from here, but change is good. :D
PostPosted: Sat Feb 25, 2006 4:59 pm
i don't know how to upload a pic on here but heres is the link to mine. http://www.luvtruck.com/Gallery/Matts80 ... index.html
i have about 3 1/2 in front and 5 in rear. it has a good rake on it. but as soon as i get time that will change. it sits on 30x10.50. havent had a rub problem yet.
PostPosted: Sun Feb 26, 2006 5:27 pm
I'll Play..... :twisted:
He's just a wittle guy so be nice :lol:
If anyone wants to go wheeling in the PNW let me know, it'll be a while before this one gets done, but i have another S-10 on 36 IROK's that would love to play in the trees and rocks with ya 8)
350 TBI, th400, np205 (soon to be doubled with a np203), 39.5 IROK's, Fullwidth Dana 44 front (soon to be spooled), FF 14 bolt (soon to be welded) on a shortened suburban chassis. 5 point harnesses, RCI racing seats. and some other stuff.
PostPosted: Tue Feb 28, 2006 9:04 pm
PostPosted: Sat Mar 04, 2006 2:06 am
those yours??? i like the ol' school paint, i saw one with the brown and gold just recently going down the hwy. dare i say i LUVed it.........*pause for laughter*............. HAR HAR HAR, i made a funnay :P
PostPosted: Sun Mar 05, 2006 2:17 am
no not mine just thought everyone would like to see some more 4x4's
PostPosted: Thu Apr 13, 2006 4:11 pm
ok i'm going to try this befor and after shots
i hope it works
PostPosted: Thu Apr 13, 2006 6:19 pm
wow i must say that paint is prety nice! 8)
PostPosted: Thu Apr 13, 2006 10:29 pm
i just took some final picks of it tonight and i'll post em later
 Post subject: Re: Stock 80 Luv 4x4
PostPosted: Fri Apr 14, 2006 12:36 am
Zane wrote:
I think it'd be cool if the come out with a Posi Kit for the Luv rear-end. =-)
You can put the LSD into a luv rear axle out of an early Trouper. Or even swap the whole axle over. You have to check its the right ratio of course theres two, 4.555 and 4.777. But you could swap the whole front diff as well.
Im not sure how it worked over there, here all the Troupers from 81-84 had the LSD and then from 85 it became an option. It changed to bigger diffs in 88 when the 2.6L 4ZE1 motor was introduced. The front diff was then the same size as the old rear diff.
The Impulse with the 5 link rear end also had the same banjo diff centre and here all the manuals had LSD and the autos got the open centre. Both were 3.9 ratio and im not sure if the low ratio gears will go on them but they do have the same spline axles.
Its not a posi kit but its something.
Bob.
PostPosted: Fri Apr 14, 2006 1:27 am
Banishment Pending
we didn't get the Trooper over here until 84 and unfortunatly they didn't come with the LSD, the Impulse diffs will work, same thing with the later Troops got the 10/12 bolt combo with the 2.6, over here we got 4.30,4.56, 4.77, and the after market makes some 5.38's (very hard to get ahold of as they don't make them any more)
PostPosted: Fri Apr 14, 2006 3:18 am
That 5.38 is out of and early one of these, Shuttle Bus.
They used the same diff but with a wider track, probably the same as the Impulse.
The ratios are just a play on two or three different pinion counts with two different crown wheels.
I wouldnt mind a 3.73 that you lot got in the autos to use in my luv. The 4.1 i got out of the 4 speed diesel will have to do i suppose.
Cheers. Bob.
PostPosted: Fri Apr 14, 2006 4:49 am
Swap Specialist Mod
OMG!!! that shuttle bus kicks ass!! i want one!! how do i get one?!?! 8O 8O :lol: :lol: :lol:
