It is currently Mon Jun 08, 2026 10:49 am
PostPosted: Wed Feb 22, 2006 12:29 pm
hey again, plans fell through on my last motor so i am in despret need of a running luv motor for my 80 4x4. it has to be on the cheap side and it has to run. i know if anyone can help its yall! i was looking at a rebuild kit for the motor with Zero compression but its like $400 and thats just for the bottom end!!! so i would rather spend 100 or 200 on a used running motor untill i get enough money and time to rebuild my motor. if you can help that would be great. thanks.
PostPosted: Thu Feb 23, 2006 5:31 pm
You need to check out a place called MP Central on ebay. I got a complete lower end..new pistons w/pins .30 over, rings, rod and main bearings .20 under, thrust bearings and all the stuff including felpro gaskets (complete set!) for less than 200 bucks!! Just got it today and I am about as happy as a pig in his own....shtuff! They are out of Souix City Ia. Sorry about the motor taking a big dump..I just went through the same thing with mine..I was able to find a runner from my local wrecking yard here for 400 but the timing chain cover was cracked. They gave me a cover for 10, and I did all the work..of course. Had to pull the head and milled it and so far..its been a good running motor. I will keep an eye open for one and if I happen to run across one, I will let you know.
Bill Lewiston Idaho
PostPosted: Thu Feb 23, 2006 7:05 pm
If you have a chev sb I'll trade you straight across for my stock motor. :)
seriously though, if you're up for a short drive there's tons of luvs here in yakima that just sit behind people's houses, you might have to take the whole truck but I'm sure you could pick one up for about $300.
2002 Lexus RX300
1998 Honda Accord
1977 Chevy Crew Cab Dually
1954 Ford F100
http://www.yvtruckclub.com/forum
PostPosted: Fri Feb 24, 2006 1:32 am
i found a motor today for $250 and i can hear it run before i buy it! if i get my truck running i will make it to the washington, oregon rally. i cant wait! thanks to brother b as that is an awsome price! and thanks to kickersolo for replying to my post! sorry thought i do not have a sbc for sale at this time, i will post to you if i do! i luv you guy's so much for the help i cant wait to meet for the rally so i can bbq up some steak and spuds... mmmm, summer! P.S. i hate WA winter's.
80 luv 4x4, 2-1/2" torsion lift, 31x10.5/r15, 3" body lift, soon rear shackle lift.
85 monte carlo, goodwrench 350, cam, headders, intake, U know... the works.
PostPosted: Fri Feb 24, 2006 3:55 pm
200 is a great price for a rebuild kit. i looked on ebay for MP central but i cant find it. is it a store? ya i will order one of them today if i can find it!
PostPosted: Fri Feb 24, 2006 4:23 pm
i cant find this guy! can you give me the ebay item # and maybe i can write him and see if he has another one for sale? everyday i sit hear is another day i am not working so... i need somthing. a motor, a rebuild kit, a whatever!
PostPosted: Mon Feb 27, 2006 11:02 am
found a motor! picked it up for 300 yesterday. i will be spending the week instaling it and trying to figger out my electric problum. does anyone know why i would have no power at the ignition switch? i have brake and head lights but nothing inside the cab. i can use a remote starter and get the starter cranking but thats it. is there a wire somewhere that i forgot to hookup? i checked and replaced all the fuses. checked the connections at the ignition and still nothing!!! i need help! thanks guy's.
PostPosted: Mon Feb 27, 2006 11:29 am
Sounds like the harness power wire or fusible link is not connected. There should be a big fat wire on the positive terminal on the battery that hooks to the starter, and a smaller wire or two that hooks into the harness on the fender beside the battery.
PostPosted: Mon Feb 27, 2006 1:06 pm
I have checked the harness and i have done everything you have said before. that did nothing. there is only a few things it can be and i have checked all that i can think of. do you think it can be the ignition switch? i replaced the missing one with this one and i do not know if it worked before. is theere any way to test the ignition switch? i have cleaned the plug and terminal and still nothing.
PostPosted: Mon Feb 27, 2006 2:03 pm
try a new ignition switch. if you checked the wires by the battery and all is cool there, sounds like to me its the ignition switch. Bill Lew. Id.
