It is currently Fri Dec 19, 2025 1:02 pm
 Post subject: Weber carb32/26DG
PostPosted: Wed Oct 12, 2005 10:46 pm
Okay.... You have sold me.
What do I need to complete the job.
1980 luv 4 speed
Carb air ,cleaner, manifold etc
Where can I buy one ?
Thank you
PostPosted: Wed Oct 12, 2005 10:59 pm
if you don’t want a new try the yards, the ones around here sell them as cores for $25 get a rebuild kit from eBay for $15/$25 and if you find one on a datsun you can use that plat it worked on my luv when I had the Weber, allot of different vehicles used the same adaptor as the luv
PostPosted: Wed Oct 12, 2005 11:14 pm
You can also try http://www.carbs.net if you want to order a new one. They sell a kit for the LUV that includes everything you need. The basic list though is a carb, carb to manifold adapter, and air filter. ctmandu is right about the base adaptor, the Datsun one is the same.
PostPosted: Wed Oct 12, 2005 11:31 pm
thank you..so far so good!
Can you gents get a little more specific?
What year and what engine Datsun?
Has there been a techical write up by anyone about a carb swap?
PostPosted: Thu Oct 13, 2005 9:12 am
this is for the adaptor and what it will fit http://www.carburetion.com/Weber/adapto ... =99004.333
PostPosted: Thu Oct 13, 2005 9:41 am
Here is a carb on ebay looks like it has at least half an adapter too...
http://cgi.ebay.com/ebaymotors/A646-DGEV-32-36-WEBER-CARBURETOR-NISSAN-TOYOTA-NO-RES_W0QQcmdZViewItemQQcategoryZ33550QQitemZ8006492066QQrdZ1QQsspagenameZWDVW
Resident lurker
PostPosted: Thu Oct 13, 2005 3:25 pm
That must be an adapter for a Toyota/Nissan like the item title says. It doesn't look quite right for the LUV even if it is just half of the two part style adapter. Hard to say though. Adapters are pretty cheap to get though and the carb is basically universal.
Users browsing this forum: Bing [Bot] and 26 guests
