It is currently Mon Feb 02, 2026 9:54 pm
PostPosted: Mon Jun 20, 2005 7:46 pm
Does anyone know if ram horn exhaust manifolds will work with early 90's corvette angle plug heads? If not who makes headers that will fit in a luv with the angle plug heads?
PostPosted: Tue Jun 21, 2005 9:52 am
Japanese Redneck
early bowtie and 292 "turbo" heads came in angle plug right out of the factory so I would have to say yes, you can run ramhorns with angle plug. beware that there are two kinds of ramhorn manifolds. the ones that you want have a larger 2" outlet.
some but not all block huggers will also work with angle plug and they will flow a little better than the horns.
I think the hooker super comp V8 LUV headers will work and fenderwell headers would work for sure.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Fri Jun 24, 2005 2:16 pm
Hey LUV - you know anyone looking to sell a set of the hooker V8 headers? Im a searchin!
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
PostPosted: Fri Jun 24, 2005 4:19 pm
The Hooker Super Comp LUV V8 headers will not work with angle plug heads. The front tubes are at an angle that make it difficult, if not impossible, to get #1 and #2 plugs in or out.
PostPosted: Fri Jun 24, 2005 4:42 pm
Well shoot, learn something everyday on here! This is good to know considering I am building an angle plug motor, oops! lol Thanks for the tip Ben!
63 Nova
74 Camaro
PostPosted: Fri Jun 24, 2005 4:49 pm
As in fenderwell are you referring to the Hedman S-10 headers like Andy is running? #65855
63 Nova
74 Camaro
PostPosted: Fri Jun 24, 2005 5:06 pm
Japanese Redneck
yes. I'm running them too until I can afford to have some custom ones made
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Fri Jun 24, 2005 5:13 pm
Japanese Redneck
dayum! you're right. brain fart.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Fri Jun 24, 2005 5:19 pm
How do they work? Did they hit any place? Torsion bar or coilover, and how come we dont have any pics of your rig? I was contemplating seeing if a set of early nova fenderwells will fit. - I need some big tubes for an angle plug motor. I want to stab my spare nova motor in my 77 in the comming winter. Did I say that??
63 Nova
74 Camaro
PostPosted: Sat Jun 25, 2005 2:59 pm
Big Bore, Short Stroke!!
Click my WWW to see my pics
 Post subject: Angle Plug Headers
PostPosted: Mon Jun 27, 2005 5:32 am
Luv4me has a website that shows how he made the Hooker Headers work on his angle plug heads.
PostPosted: Mon Jun 27, 2005 10:32 am
Japanese Redneck
if you're going with coil overs, depending on where your motor sits it should clear everywhere but its very close to where the top of the shock tower used to be and very close to the master cylinder (vacuum booster removed). nova fenderwells will not fit. been there tried that. somebody a while back also said V8 conversion headers for a toyota land cruiser will fit. i guess it depends on how the motor is mounted in but using the hooker conversion mounts and mounting it in to their specs, landcruiser fenderwells WILL NOT without massaging the shock tower and the firewall. the Heddmans S-10's come in 1 7/8" or 2" primary. thats a decent size tube.
I don't normally post pics of myself or cars on the net.... I don't even post pics of myself on the streetracing website that used to own. I may break tradition and post some pics of my motor and my new Pro Topline heads very shortly.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Jun 28, 2005 12:59 pm
The truck I had and sold has the hooker long tubes in it with angle plug heads. The # 1 tube was cut and a piece added in to give added clearance. This was done for almost no money at all. Now those heads are the old Brodix track 1 heads. We have another truck with some top proline heads and no mods to the tubes and they clear just fine. I dont know if it is a sliglt diff angle on the plug holes or what but I know they work just fine with the new style heads.
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Fri Jun 30, 2006 1:07 pm
I am running a set of angle plug heads with full length headers without modifing the headers. the torsion bars have to be removed. I have to look up the name, and i"ll post it or you could just email me.
PostPosted: Sat Jul 01, 2006 9:01 am
I have 210 gmpp fast burns angle plug with hooker super comp block huggers and they clear.
 Post subject: headmen long tubes
PostPosted: Sun Jul 02, 2006 10:05 pm
i am going to use some headmens long tube 1 and 3/4 , made for a 69 camaro they will fit angle plugs heads but the torrison bards will hve to come out, got my headmen headers and they will not fit in engine bay, could someone plz help, got to send them back to summit
