It is currently Wed Jun 17, 2026 2:57 am
PostPosted: Sun Apr 03, 2005 10:40 am
what would i have to do to get it to work?
PostPosted: Sun Apr 03, 2005 1:50 pm
as long as you make a custom bracket It should fit fine.........I have a TH350 in mine...but I'm shure someone with a 400 could chime in snd give s little more insight
If everybody grows up with high self-esteem, who is going to dance in our strip clubs?
What's going to happen to our porno industry?
These women don't just grown on trees.
PostPosted: Sun Apr 03, 2005 1:54 pm
are we talking about the same thing?
im talking about the engine and trans
i already have turbo 350 in my truck as well
PostPosted: Sun Apr 03, 2005 3:10 pm
oh...ok I thought your were talking about a 400r tranny. 400 engines will fit fine....I know for a fact LUVNIT has one in his....and probably more on here
PostPosted: Sun Apr 03, 2005 3:38 pm
the pontiac 400 will fit, you just need to tweak the mounting process a bit due to the different size of the engine. fire up your search button.. somewhere on here is a topic discussing some particulars. I know it can be done and it's not that much harder than the SBC swap.
PostPosted: Mon Apr 04, 2005 2:00 pm
Any engine will fit, just depends how much work you want to put into it. :wink: Good luck. :)
PostPosted: Thu Apr 07, 2005 7:25 pm
got a 400 in mine out to a 406 and it fit fine and with macanical fan still on it and all of it below hood by 2 - 3 inch clearance :wink:
http://bonsaint.com/luvalbum2/index.htm
more pics of my 76 406ci 4 spd posi.
PostPosted: Thu Apr 07, 2005 7:58 pm
nascar...isn't your's is a sbc? agent is talking a 400 poncho motor. someone posted about this on here before and had some info actually on performing the swap.. here's a link..
http://forums.luvtruck.com/viewtopic.php?t=4812&highlight=pontiac
PostPosted: Thu Apr 07, 2005 10:06 pm
yes it is i must have missed something
 Post subject: Pontiac and th400
PostPosted: Fri Apr 08, 2005 10:35 pm
, because everything is a little bigger, and a little different. Bigger means more cutting and fabbing, and more expense. I have to tell you the " how to engine and trans install for a Chevy 350/350 " that Ben has put on this site is worth a lot of money. It would take you weeks of continious looking and asking questions to come up with what they have "given us ". If you really want to do it right, buy a Hemmings motor news, and find the people selling the SHOP MANUAL for the year Pontiac engine and trans that you have. It will give you the dimensions and weight of the engine and trans, and maybe the motor mount measurements. Take it from Hooker, and Hedman Header Companies they make headers for putting a Chevy 350/350 into your Luv. They don't make them for Pontiac. If you don't have several engine swaps under your belt, you probably should not attempt it. It will cost you much less to go fast, if you sell the Pontiac, and buy a Chevy setup. They are cheaper to buy and parts are abundant. Pontiacs are good engines, but they are much more expensive to build. For the same money you will spend, I can build a Chevy that will be faster lighter, and easier to sell when the time comes, plus because of the parts availability I can build it a lot faster. Not trying to rain on your parade, just giving you the cold hard facts.
 Post subject: Chevy Luv
PostPosted: Fri Apr 08, 2005 10:44 pm
I thought you sold your truck.
