It is currently Mon Jun 29, 2026 11:52 pm
 Post subject: Pedal Sensors
PostPosted: Mon Dec 20, 2004 2:37 am
There are sensors on the brake, clutch, and gas pedals...
I know the one on the brake is for the brake lights, but what are the ones on the clutch and gas pedal for?
Thanks
PostPosted: Mon Dec 20, 2004 6:11 am
clutch = neutral start switch
accellerator = fast idle or something.....??
03Cobra
PostPosted: Mon Dec 20, 2004 9:39 am
I think the one on the gas pedal is for the coasting richer solenoid on the hitachi carb.
1980 Luv Mikado 4X4
PostPosted: Mon Dec 20, 2004 1:03 pm
The clutch actually has two depending on the year. One for starter safety and one for the coasting richer system. I think 77 or older lacks the starter lockout switch.
The coasting richer system is setup to give the motor a little more fuel if three things are true:
Gas pedal not pressed
Clutch not pressed
Trans in 3rd or 4th gear
That is where all the switches come from. The idea is that the truck needs a bit more fuel when coasting in order to maintain good emissions.
PostPosted: Thu Dec 23, 2004 12:32 am
my 72 does not have the neutral lockout switch as well.
also, i believe the coasting ericher system retards the timing with the dual point setup...that has been disabled on mine and am now just using the advanced points with a weber. minimal backfiring, but still a little bit.
