It is currently Wed Jul 01, 2026 12:43 am
PostPosted: Sat Nov 27, 2004 8:17 pm
Got a prob. The piece that holds my exhaust pipe to the manifold is bent to piss and leaks like mad. Kinda leary about suckin' a valve.
bigger prob, the pipe is dented where it bends under the truck so I can't slide the old piece off or I would take it off and replace it.
One more prob, there's no cat on my truck so there's some smaller pipe there held together with u-bolts that are so rusted they might as well have been raised from the titanic.
How much work is it gonna be to fix this and how much will it cost me? This is priority cause it's freagin' cold out here and I don't want to drive it with the leak like that. it sounds really, really bad.
1980 Luv Mikado 4X4
PostPosted: Sat Nov 27, 2004 8:24 pm
Hey man....glad to hear it's running again.(BIG applause) :multi:
PostPosted: Mon Nov 29, 2004 7:05 pm
to fix those problems it would probably me about a 3 on a scale of 1 to 10 money wise with 1 being the lowest and on time scale i would probably say a 5
PostPosted: Tue Nov 30, 2004 12:28 am
hey cut from ur problems back and i will send u a piece that goes from the manafold , manafold gasket and a couple hagngers just weld those on some where underneth and then give me the angles and i will bend u every thing u need then just weld it all in and bolt down the gasket and gaskit plate to the manafold. ill draw it up. pm me and tell me wat size pipe u need and all that. HOPFULY U HAVE A WELDER
Users browsing this forum: No registered users and 62 guests
