It is currently Mon May 25, 2026 10:51 am
PostPosted: Mon Nov 01, 2004 9:12 pm
Luvtruck.com Wookie
Ok....i got my new fuel pump cause the stocker doesn't keep up w/ my Weber.
got the holley red......how do i set the relef valve? Do i even need too?
i suspect the big screw plug covers the relef valve but i can't get it to open.
the pump specs are; 97 gph free flow,78 gph at 4 psi, 7psi max.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Tue Nov 02, 2004 1:52 am
hey how much was that pump and were did you get it, i need one for my luv because i got a weber and the bowl goes dry after it idels for about 3-4 mins its a pain in trafic.
kevin
PostPosted: Tue Nov 02, 2004 2:19 am
I had a weber on mine before I did my v8 swap, and never had any trouble.
 Post subject: Fuel Pump
PostPosted: Tue Nov 02, 2004 10:07 am
I just bought and installed a new Holley 'Blue' on my truck. I was just replacing an older one. I already had a regulator installed by the carb. But the pump came with a new regulator and a small book of instructions on how/what/where/why to do all that. Did you get it new, with instructions? It should all be in there.
Jegs has all sort of fuel pumps, the red is about 100 bucks in the catalog.
PostPosted: Tue Nov 02, 2004 1:38 pm
how does the holley work is it for a v8 orfor the 1.8 i have never been able to find another company that makes carbs for luv 1.8 i just was wondering how they performed?
kevin
PostPosted: Tue Nov 02, 2004 8:24 pm
Luvtruck.com Wookie
i got the holley in today.....YEAH!!!! it got rid of all the top end-full throttle missing that i had. this makes fifth gear useable now.
the red is made for low pressure performance carbs... it doesn't need a regulator with the Weber.
i fired up the pump without it being hooked up to the carb and it shot a 10ft long 5/16ths jet of fuel. 8) :oops:
I have a saftey question though..... i mounted this thing in the engine compartment.... is this a bad idea? it is hooked up through the relays properly so it doesn't run unless the engine's running or i'm trying to start it.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Nov 03, 2004 9:50 am
According to the instructions with the 'Blue' I just put in mine as well as everything I have ever seen, it can NOT be mounted in the engine compartment. Two reasons; one fuel supply, they are supposed to be mounted as close to the fuel source as possible. two, safety. I have fuel cells mounted in the back of the truck, so I have mounted the pump underneath the tanks. With the stock fuel tank, that might be a little harder to do, but I would definately move it out of the engine bay.
PostPosted: Tue Nov 09, 2004 12:37 am
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 55112&rd=1
is it close to this one?
kevin
PostPosted: Tue Nov 09, 2004 7:43 pm
Luvtruck.com Wookie
that's the critter.... do your self a favor and don't mount it anywhere near the body.... i have mine insulated and sheilded under the hood and it's still noisy as hell.
see if you can get it mounted somewhere near the stock location... WARNING..... you'll need a drill
TiLtEd wrote:
Boobies!!! :D
PostPosted: Tue Nov 09, 2004 9:16 pm
Noisy as Hell? But the listing says "Lower noise" 8)
Wonder how loud it would be otherwise?...
Resident lurker
PostPosted: Tue Nov 09, 2004 11:49 pm
Luvtruck.com Wookie
it has more to do with the chevy luv's body acoustics than anything else....
the new carpet i scored will probably help that quite a bit.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Nov 10, 2004 1:32 am
waring i will need a drill.... i am not bashful when it come to drillin, cutting, bending, ect. :twisted: :twisted: :twisted: i am gona bid on that sucker and put it in my truck. thanks you all have been a HUGE help.
kevin
Users browsing this forum: Bing [Bot] and 37 guests
