It is currently Mon Mar 23, 2026 6:54 am
 Post subject: ford 9in rear end
PostPosted: Wed Dec 18, 2002 7:48 pm
Simple question but all those 9in rear ends people out there are using have they all been narrowed or is there a one that is the right size , also I am going to visit a read end builder I know to see if he knows of any magic fits Jim
PostPosted: Wed Dec 18, 2002 8:51 pm
Mine has been narrowed.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Wed Dec 18, 2002 9:13 pm
Mine has been narrowed to 39"
stripped and just a memory!
PostPosted: Wed Dec 18, 2002 10:09 pm
39 inches.... I was wondering how wide, I just never asked....
What points is that measured from?
PostPosted: Wed Dec 18, 2002 11:55 pm
Mine wasn't narrowed. It is just barely wider than stock. I believe it is out of an older Ranchero or Falcon. The wheels should still tuck up under the fenders. It will take greater back spacing on the rims.
PostPosted: Fri Dec 20, 2002 3:32 am
how long would it take to swap?2 hours??
PostPosted: Fri Dec 20, 2002 8:03 am
The 39" is wheel to wheel total outside width.
PostPosted: Sun Dec 22, 2002 10:21 pm
FYI- my 9 has about 1.5 " of the round axle housing on the one side, and there is almost none on the other. I had it done in seattle, and EVERYTHING is way too expensive over there. That been said, i still found a guy that had a full shop out of the main city who did all the work for $175. he is a sprint car racer, and was all set up to respline, cut and weld.
I also found another guy to install my clutched locker and new gears. $150. he was all set up too. the key was to find an auto supply store where the guys know everyone in town or in the area.
A fine print note on my 9"- I have a locker with clutches. Basically it performs like a positraction. Anyway, you go through a few weeks of HECK trying to figure out what is rubbing, grinding, or falling apart- especially when turning. Its the plates in the locker. you think your tires are rubbing, or your locator bar is loose and the axle is floating around. Scares the crap out of you. You pull over constantly, stress out completely, until you hear that others have the same thing. FYI.
"G"
 Post subject: 9"
PostPosted: Tue Dec 24, 2002 2:11 pm
Japanese Redneck
the narrowest rear end you will find is propbably off a 1957 Ranchero. some other narrow ones are off of a 67-68 Cougar or late 60's mustang. and of course the good ol Lincoln Versaille disk brake one. None of them are perfect with respect to the stock luv rear end fit but those will get you the closest. These days its pretty cheap to have one narrowed down. After market axles are even pretty cheap. If you are on a budget, you can try a 8" rear end off an early mustang or cougar. They will handle a decent amount of HP and are easy to find.
