It is currently Sat Jun 13, 2026 11:21 am
PostPosted: Mon Oct 04, 2004 9:40 pm
PICKED UP A 77' F150 WITH A 351M AND WAS THINKIN I WOULD BE A GOOD LUV MOTOR....LET ME KNOW WHAT YA THINK
1-2 it's not new, 3-4 shave the door, 5-6 learn some trix, 7-8 make it scrape!, 9-10 show your friend!
PostPosted: Mon Oct 04, 2004 9:52 pm
Good idea :!: IF.....you can make it fit 8O
I've always said that"Anything will fit in anything if you have the tools, time and patience". 8) I put 440 Mopar into a Lil AMC Gremlin yrs ago, so what you're up against there should be a breeze compared to that. :D :wink:
PostPosted: Tue Oct 05, 2004 10:58 am
Japanese Redneck
theres a blue LUV in the gallery that has a 302 in it. if that fits then a 351w should fit. It aint that much bigger.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Oct 12, 2004 8:48 pm
Quote:
...a 351w should fit...
Yea, but he's got a 351M, which is a de-stroked 400, so its a bit bigger than the Windsor. If'n a 454 Chebby can be swapped into a LUV, then the 351M should be fine. Just a matter of money, patience, & skills. :wink:
'46 Studebaker truck "project"
'90 Trooper 4X4, 2.6L 5 spd
PostPosted: Tue Oct 12, 2004 8:55 pm
According to my boss (ford guru). . .The 351 Windsor and Modified engines have the same block but the modified has "modified heads" that displace more. I dunno, stopped being a ford guy when my crown vic went down.
1980 Luv Mikado 4X4
PostPosted: Tue Oct 12, 2004 9:09 pm
LOL- he ain't no Ford guru. :wink: Completely different blocks. The Modified is a big block & has the same bell housing pattern as the 460. Its considered part of the 335 series engine family, which is 351C, 351M, 400's. (429/460s are the 385 series)
I can't remember for sure as I don't consider myself an expert, but the Boss 302 engine was a 302 block w/ 351C heads. The 351C heads can also be used on the Windsor, giving you the "Cleavor" engine, IIRC. I'll be darned if I can't remember if the C uses the same heads as the M, though.
PostPosted: Tue Oct 12, 2004 9:12 pm
Hmm, food for thought. Time for some I-told-ya-so's.
1980 Luv Mikado 4X4
