It is currently Tue Jul 07, 2026 11:54 am
 Post subject: Water pump threads?
PostPosted: Wed Sep 22, 2004 7:38 pm
I need to replace the connector that joins the waterpump and the hose on top and the plug that goes in the left hand side. I have the replacements, and the threads match, but I'm worried about leaks. Will regular plumbers nylon tape work?
Thanks,
Jess
PostPosted: Wed Sep 22, 2004 8:20 pm
Banishment Pending
there should be a rubber seal w/ the water pump, so you shouldn't have to worry about leaks.
PostPosted: Wed Sep 22, 2004 8:29 pm
Nope, just the standard cork gaskets, nothing for the connectors
PostPosted: Wed Sep 22, 2004 8:32 pm
Banishment Pending
Hmmmm, in that case i would recomend Teflon plumbers tape for the connectors
Users browsing this forum: No registered users and 76 guests
