It is currently Sat May 09, 2026 8:18 am
PostPosted: Thu Dec 12, 2002 9:35 pm
help i need to know if a speedo cable from an s 10 or some other chevy will wirk on the luv i cut my stock one to work a couple different times but u have to grind the end square and i cant seem to center it and it breaks please help :)
PostPosted: Fri Dec 13, 2002 12:03 am
I had trouble finding one for mine at the local shops. I finally took it to a speedometer shop and they had one that worked great. The guy even acted like, "ya, of course we have one".
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Fri Dec 13, 2002 6:05 am
when I needed one, I went to a shop.....(dont even know what they did there) anyhoo they cut the end that goes in the tranny and attatched the square end that it needed.
03Cobra
PostPosted: Fri Dec 13, 2002 8:12 am
Shucks has a replacement speedo cable for really cheap and it has the square ends and end pieces with it. I think they also have 2 different lengths as well and they are both under $15. I hope that helps.
