It is currently Fri May 08, 2026 10:46 pm
 Post subject: Timing Chain ??
PostPosted: Thu Dec 05, 2002 9:11 pm
Does anyone know if a stock 79 Luv engine bends valves when it jumps time.I bought a parts truck and it is 4 wheel drive and my son wants to see about getting it going to play! :roll: I hope this one doesn't get out of hand like mine did. :!:
stripped and just a memory!
PostPosted: Thu Dec 05, 2002 9:58 pm
i can tell ya a 1980 does,
thats the reason im putting the v6 in mine
PostPosted: Fri Dec 06, 2002 6:15 am
Hey RAT knowing you it will get out of hand......
I think I might have an engine out back if you need anything for it.....I will look tonight and let you know.
not a clue when it ran or if it is even good, but I will look.
03Cobra
PostPosted: Fri Dec 06, 2002 9:05 am
when the chain on my stock 75 motor snapped, i thought for sure that i bent every valve but come to find out, none of em bent. mine had enough clearance between the valves and pistons. But i think 75's had a different head than a 79.
