It is currently Sat May 09, 2026 9:10 pm
 Post subject: traction bars and tires
PostPosted: Sun Nov 03, 2002 11:20 pm
i have a stock 79 chevy luv and we're puttin a 305 sb in it. i was wondering what traction bars i can use with out modifying anything and i ws also wondering whats the widest tire i can fit under it. please responde cause i have no clue. thanks!
 Post subject: tires
PostPosted: Sun Nov 03, 2002 11:30 pm
i used a 275/60/15 with the rite offset wheel it will work, any bolton
traction bar will work
PostPosted: Mon Nov 04, 2002 11:54 pm
thanks for the feed back
 Post subject: slapper bars
PostPosted: Thu Nov 28, 2002 9:26 am
Japanese Redneck
slapper bars work fine but the longer the better. you want the snubber to be as close to the front leaf spring eye as possible. At the drag strip I remove the rubber snubber and put in a bolt with a 1/2 gap between the bolt and the spring. it makes a little "BANG!!" noise when you hit the gas but that works like a charm and the truck launches like a mofo. I would also recommend a Cal Trac or similar traction bar for ANY street driven leaf spring car.
PostPosted: Thu Nov 28, 2002 11:05 am
IF YOU WANT A SUPER CHEAP WAY I THINK IT WAS BEN THAT SAID HE BULT HIS OWN. IF I REMEMBER RIGHT IT WAS 2" SQUARE STOCK .190 THICK. THEN YOU CAN CUT THEM TO THE RIGHT LENGTH PUT A POLY SNUBBER ON THE END YOU WILL BE SET. 8)
PostPosted: Thu Nov 28, 2002 12:32 pm
Ya, that's what I'm using. I welded them to the bottom spring plate which seems to work the best. Mike Saiki is using almost the same setup too.
