It is currently Sun Jun 07, 2026 9:26 pm
 Post subject: Going Crazy!!!!!
PostPosted: Mon May 24, 2004 2:02 pm
Ok I have been workin on this 79 LUV for a week now. :( I have replaced all the minor stuff and rebuilt the stock Carb. I am getting good spark and I can smell gas in the Carb but still no go. :( If I spray a little starting fluid in it, it will puff some black smoke but still no go. Some one please help :!: :!:
PostPosted: Mon May 24, 2004 2:17 pm
Have you checked your timing.......and have you replaced fuel filter
PostPosted: Mon May 24, 2004 3:06 pm
Ok I'm an idiot :!: Instead of looking in the book for the firing order I followed the marks on the cap. Fixed that problem.
I then got it to turn over but now the only way to keep it runnin is to contiually pump the gas. My guess is the Carb but I am not much of a carb expert and I am not sure how to diagnose it. when I rebuilt it I put everything where is goes and thought I set everything where it should be.
Once again Please Help
PostPosted: Mon May 24, 2004 3:20 pm
Check all the small vacuum hoses for loose or split ends that would allow air to be sucked into the carb and lean the mixture out.
PostPosted: Mon May 24, 2004 3:25 pm
All brand new hose routed properly
thanks
PostPosted: Mon May 24, 2004 8:31 pm
Luvtruck.com Wookie
make sure all the vac is routed correctly, my vac diagram(stock under hood)was DEAD WRONG
make sure that the advance is getting straight vac from the manifold
TiLtEd wrote:
Boobies!!! :D
PostPosted: Mon May 24, 2004 10:27 pm
FILTERS??????
PostPosted: Tue May 25, 2004 6:44 am
Luvtruck.com Wookie
in light of the fuel tank thing ..luvinit brought up a good idea.
take the end of your fuel pump off and take the filter out..It's probably full of the same crap that is in your tank
before you do this though get a few spare inline filters ,you'll be replacing them a couple times, also you could run the fuel line from the tank to a gas can w/ clean fuel.
Ihave to work out of town today so I'll get ahold of you tonite about your fuel tank.
good luck
TiLtEd wrote:
Boobies!!! :D
PostPosted: Tue May 25, 2004 10:13 am
Yeah I checked the new filters and they were cloged with crap. So to get a good test goin I ran the line that comes from the tank and the return line in to a clean gas can. That kept it runnin but rough, my question now is how to properly adjust the carb for best perfomance. The Timing is dead on BTW. Thanks for all the help.
PostPosted: Tue May 25, 2004 10:51 am
Take the spark advance vacuum line off at the manifold and suck on it. If you draw air the diaphram is leaking.
PostPosted: Wed May 26, 2004 12:04 pm
Make sure your IDLE JET in the carb is also not plugged up.
On my weber DGV The only way to keep it running was to pump the gas. So what I was doing was using the accellerator pump to keep it running(You see gas squirted into the barrel).
Would run ok at high rmp but by them Im using the main jet, circut.
PostPosted: Wed May 26, 2004 5:56 pm
Luvtruck.com Wookie
set the timing to 8 degrees and the point gap to .018....my my.....i don't know what all you need to clean on the carb, but you can take out the idle stop solinoid and flush the needle seat area out and run some concentrated in tank cleaner through the gas in the can.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed May 26, 2004 5:57 pm
Luvtruck.com Wookie
damn mouse........
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed May 26, 2004 9:57 pm
Thanks for the Tips as soon as I get the new tank I will try it.
PostPosted: Fri May 28, 2004 7:55 pm
Luvtruck.com Wookie
that tank's on the way......wifey sent it this morning.
good luck, i will e-mail you a tracking # as soon as she get's in k?
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sat May 29, 2004 1:05 am
ok thanks again
PostPosted: Sat May 29, 2004 11:54 am
When I first had my Luv, it has a lot of gunk in the tank, I went threw several filtser and rebuilt my carb twice. I ended up removni the fuel tank, having it boiled out and sealed. I wish I would have done that to being with.
Also antheor problem I ran into since the truck sat a long time, there was a lot of gunk and rust in my master cyclinder. My advice is to tank care of fuel tank and master cycleder if you get any vehicle that sits for a long time.
PostPosted: Mon Jun 07, 2004 6:46 pm
:D I got the tank in today! :D
Before I hooked the Filters tank and pump up, I blew air backwards the the line and blew out all sorts of crap from the solid lines. Installed everything and WOW :!: does it run smooth.
Thanks again for all the advise and thanks to where's all the luv at? for the tank, your a live saver.
PostPosted: Mon Jun 07, 2004 7:05 pm
Luvtruck.com Wookie
congrats dude, you are so very welcome.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Mon Jun 07, 2004 7:20 pm
Luvtruck.com Wookie
there's a service tip for any one who has an older vehicle...20 dollars worth of stainless steel bb's,a few gallons of ethel and a concrete stinger........ cleans anything. you should do this about every fifteen years or so depending on what grade gas u use.
TiLtEd wrote:
Boobies!!! :D
Users browsing this forum: Bing [Bot] and 47 guests
