It is currently Sun Jun 07, 2026 7:46 pm
PostPosted: Mon May 17, 2004 9:06 pm
What is a good set of shocks that won't cost an arm and a leg for my 80 4x4??? By the way it is used mostly for around town and on hunting trips where things can get a little rough to a lot rough.Thanks for the help.
PostPosted: Mon May 17, 2004 10:13 pm
rancho and pro-comp are decent shocks...usually around 130-150 or so a set at 4wheelparts
PostPosted: Tue May 18, 2004 7:06 am
I have KYB's on my truck and they work really good, especially if you put some weight in the truck at times.
PostPosted: Tue May 18, 2004 9:35 am
I purchased $20 shocks from autozone for my blazer and they work great.
I think they are gabriels
03Cobra
PostPosted: Tue May 18, 2004 10:50 am
Mine are Monroe's and they make the ride smoosa.
PostPosted: Thu May 20, 2004 8:06 am
I just bought some Monroe's and haven't put them on yet. I've been wondering whether they will make a difference or not. Everytime I hit a bump, I feel like I am going to crack a rib or something. Hopefully putting them on this weekend.
Any tricks to the make the install easy? or anything I should know? never replaced shocks before.
PostPosted: Thu May 20, 2004 10:55 am
Sometimes it is alot easier to have an extra set of bolts around.
If you have to cut the bolt, get a dremmel and cut the nut off. it makes it really easy to keep spare parts around!!!
I notice quite a difference between the HD shocks and the car shocks. So if you want your fillings, you might want to get a softer non Heavy Duty shock.
Users browsing this forum: No registered users and 59 guests
