It is currently Sun Jun 14, 2026 4:22 pm
 Post subject: Vent window seals
PostPosted: Fri Mar 28, 2025 10:00 pm
Has anyone found replacement vent window seals.
76 LUV
 Post subject: Re: Vent window seals
PostPosted: Mon Apr 07, 2025 4:18 pm
You can get them on eBay from Thailand but I've heard quality is pretty sub par. Best bet would be to talk to a seal manufacturer and see if they can do a run, or talk with your local glass shop and see what ideas they have
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Wed Apr 09, 2025 8:05 pm
Restoration specialties .com. You'll probably have to talk to them on the phone, but they'll have a close match that will work fine. That being said, it was more than 10 years since I did business with them, but they were great.
PostPosted: Sat Dec 13, 2025 7:03 pm
I got a set on eBay. They were not even close to fitting. I tried to get them to some how fit but no luck. Also I have question about replacing the dash, on a scale of one to ten how difficult is it. I have a factory dash that I’ve had for a few years and I’m ready to install it.
76 LUV
PostPosted: Sat Dec 13, 2025 7:13 pm
3 gauge cluster wing nuts, remove vents and screws, take out glovebox, there might be a bolt or 2 hiding above the ash tray. Getting the new dash to fit to your liking is the hardest part from my experience.
I'm workin' on it
SBC
