It is currently Fri May 29, 2026 11:57 am
 Post subject: Electronic distributor
PostPosted: Fri Mar 07, 2025 8:40 am
Guys what year of Isuzu Pup distributor do you use to convert from points? My 75 isn't running and I think it's the pickup coil.
PostPosted: Fri Mar 07, 2025 2:29 pm
I think 1982 ish. But instead of used junk yard parts, I'd go with a Pertronics conversion kit. It replaces your points with electronic ignition and fits into your existing distributor.
PostPosted: Sat Mar 08, 2025 6:44 am
I think the pickup coil is shot. It will pop when you start it but won't run. Power to everything. No pitting in the points and they open and close.
PostPosted: Sun Mar 09, 2025 9:05 pm
have you checked for spark on all 4 plugs? sounds like a timing problem if you have spark. +1 on the pertronix kit. you can also get remanned electric dizzy from auto parts stores or rock auto
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Mon Mar 10, 2025 7:24 pm
I am going to get the distributor. It started blowing fuses. I think the pickup coil has a dead short.
