It is currently Sun May 24, 2026 4:46 pm
PostPosted: Fri Sep 23, 2022 5:36 pm
OK it is getting fuel and spark but won't stay running. Does the alternator put out a signal to keep the truck running. Anybody else have any ideas? Points are not pitted at all. Tried a different coil and it does the same thing. Has been in storage since this started. After four years I am finally getting to it! Any input would be greatly appreciated!
PostPosted: Tue Sep 27, 2022 11:02 pm
Possibly stuck bowl float.
Tom
PostPosted: Wed Sep 28, 2022 5:17 pm
It was doing this before it sat. Was my daily driver. Weber carb. Running two fuel filters. Fresh fuel, new battery. Could it be the ground from the negative cable to the body? 70's G bodies I have had in the past won't start if it is bad.
Users browsing this forum: No registered users and 66 guests
