It is currently Tue Jun 09, 2026 7:53 pm
 Post subject: Air Injection Delete Tip
PostPosted: Thu Jun 10, 2021 10:22 pm
I am rebuilding my G180, and deleting some emissions systems. I thought I’d share this technique with those who are finding trouble plugging the air injection holes in the head. Being that the holes are an M14x1.25, finding a bolt to plug it is difficult. So I just cut off the plugs, and used an impact to pound a 3/8x16 bolt into the middle of the plug. It had the same 14mm head, and I didn’t even tap it. Maybe not the most airtight, but an easy fix nonetheless.
PostPosted: Fri Jun 11, 2021 6:30 am
Have you had the opportunity to do a compression check yet?
