It is currently Mon May 25, 2026 4:39 pm
 Post subject: Gas cap problem
PostPosted: Sun Mar 21, 2021 5:45 am
The gas cap fell off the truck, so I tired to buy a new one, twice they didnt fit when they were supposed to fit but didnt. Any ideas on what to do
 Post subject: Re: Gas cap problem
PostPosted: Mon Mar 22, 2021 8:42 am
The early Luv's had a smaller gas cap. I am not sure of the cut off year 75-76? The ones you see mostly are for the later years. If you tried one that didn't fit I would guess you need the earlier size cap. You might even try a Datsun or Toyota cap from the same year as your truck. Good Luck
PostPosted: Tue Mar 23, 2021 11:02 am
You could get a replacement filler tube (not sure if that's the right name) I put a different bed on my luv, and it had the same issue. The section were the cap goes to the bed had a bolt on the back. At least that's how I would go about it.
PostPosted: Tue Apr 09, 2024 7:40 pm
Did you ever find a compatible fuel cap? I’m in the same boat as you were.
