It is currently Sun Jun 14, 2026 10:26 am
PostPosted: Tue Aug 04, 2020 10:46 pm
Can i pull my power steering pulley, and just replace cap on crank pulley without screwing anything up?
I'm looking at getting the 24x19 radiator and fan combo from griffin radiators. However its 1/3" too deep to keep my current pulley system as is. I dont use power steering currently, so it wouldn't negatively affect my LUV in that capacity.
Thank you in advance,
-KB
PostPosted: Wed Aug 05, 2020 5:10 pm
Wonder what the vehicle is.
PostPosted: Wed Aug 05, 2020 6:27 pm
Hahah, I'm sorry. 1976 Chevy Luv
PostPosted: Wed Aug 05, 2020 8:15 pm
I’d imagine you could do this... however, these trucks never had power steering from the factory. Not sure what conversion has been done to yours.
PostPosted: Wed Aug 05, 2020 10:34 pm
What's the outer pulley/missing belt for? I got the truck without these parts
PostPosted: Thu Aug 06, 2020 10:18 am
Would that outer pulley & missing belt be for models that came with AC?
Either way, does anyone know if these pulleys separate or if I need to find a single groove pulley to replace it with?
Something like this... https://www.speedwaymotors.com/Holley-9 ... 91663.html
PostPosted: Thu Aug 06, 2020 10:51 am
Yeah the mikado models came with ac. Not sure if the pulley separates but you could maybe find a single groove in a junkyard or buy one from someone here.
PostPosted: Thu Aug 06, 2020 3:28 pm
Thank you
PostPosted: Fri Aug 07, 2020 6:55 am
Looks like the crank pulley is single groove and the water pump pulley is double.
PostPosted: Sat Aug 08, 2020 10:28 am
:oops: thank you so much. That should help me tremendously
PostPosted: Thu Aug 20, 2020 10:29 pm
Yes those are two separate pulleys and you can remove the outer one. You may have bolt length issues to deal with, but it can be done I think.
PostPosted: Sun Sep 06, 2020 3:18 pm
So after some other projects took over, I finally got to check on those pulleys. They do come apart, however the water pump shaft still sticks out too far. Is a shorter shaft water pump made for those who don't run AC?
PostPosted: Sun Sep 06, 2020 3:51 pm
A/c trucks had a fan clutch. Non a/c had no clutch and a fan with fewer blades. I'm thinking that's where the problem is. Different style fans have different thicknesses.
PostPosted: Sun Sep 06, 2020 5:32 pm
https://www.griffinrad.com/load_details ... make=Chevy, Dodge&model=Racer&select_Main_Group=0-400&select_Sub_Group=TL&select_Sub_Group_model=BR&select_Sub_Group_Engine=Manual&select_Sub_Group_HorsePower=24x19x3&key_id=1-25202-X
Well this isn't an overly thick rad/fan combo. It is within 1/4" of fitting, but that gosh darn water pump/pulley shaft.
PostPosted: Sun Sep 06, 2020 5:40 pm
trying to post picture attachment and suddenly failing at it.
File comment: As you can see, I got the 2nd pulley off, but even putting on an after market single setup, that shaft is still poking out. I know small blocks came with short and long shaft water pumps. But don't know anything about this isuzu setup
PostPosted: Sun Sep 06, 2020 5:44 pm
I'm trying to remember, I think a spacer is used in place of the pulley. I doubt there two different water pumps for these trucks. I know what you mean on the SBC though.
PostPosted: Mon Sep 07, 2020 12:49 pm
Not sure if it is any help, but this is from the factory parts book.
PostPosted: Mon Sep 07, 2020 12:54 pm
Crank pullies.
