It is currently Fri Mar 20, 2026 6:06 pm
PostPosted: Tue Nov 06, 2018 12:11 pm
HI IM NEW TO THE SITE AND NEED SOME HELP.I HAVE CUSTOMER WITH A 1982 LUV MIKADO WITH THE DIESEL ENGINE .THE FRONT SEAL IS POURING FLUID AND I CANT FIND A REBUILT PUMP ANYWHERE.CAN SOME HELP TO POINT ME IN THE RIGHT DIRECTION ANY HELP WOULD BE GREATLY APPRECIATED. THANKS IN ADVANCED.
PostPosted: Tue Nov 06, 2018 2:31 pm
If you look it up on rockauto there's a place that will rebuild it for $117 you ship.
PostPosted: Tue Nov 06, 2018 5:07 pm
Clean off the pump and carefully remove old seal. There should be a part number stamped into the edge of old seal that may be used as a cross reference to help find a new seal. Then just replace the seal and save the pump. Hope this helps.
PostPosted: Tue Nov 06, 2018 11:09 pm
Where are you? I know of a place in so Cal that might rebuild what you have. I would think there are shops all of the place if you can find them.
PostPosted: Thu Nov 08, 2018 4:34 pm
All good advice. As far as I know, replacement pumps are no longer available, unless you happen to stumble onto someone with old stock.
