It is currently Sun Jun 16, 2019 11:19 am
 Post subject: Bearing Spacer??
PostPosted: Sun Feb 11, 2018 1:51 pm
I am replacing my bearings in my '79 4 wheel drive. Long story short, i destroyed the spacer that holds the inner bearing in place. I have not been able to find this part at any parts stores, so i have decided to see if anyone on here could help me out. I will try to post a picture of the piece i am looking for.
I also am replacing the bearing seals. I found them on autozone that supposedly fit, but when i received them in the mail they are a different material and a little thicker than what was in there.
 Post subject: Re: Bearing Spacer??
PostPosted: Sun Feb 11, 2018 1:58 pm
Spacer - #2 (94021319)
Seal - #17 (94224173)
PostPosted: Sun Feb 11, 2018 4:04 pm
Best bet is to take the one from the other side to a machine shop and have one made...
PostPosted: Sun Feb 11, 2018 10:52 pm
Also the part numbers you have listed are for a 2 wheel drive and will not fit your 4 wheel drive.
PostPosted: Sun Feb 11, 2018 10:54 pm
Well they are both tore up. We got a little ahead of ourselves trying to get the bearings out and tore them both up on the process. Dumb mistake
PostPosted: Mon Feb 12, 2018 9:35 am
Outer bearing
Inner bearing (link says it's a transmission bearing, but it has the correct part number)
Bearing seal
Bearing ring
As I said above, you were searching for the incorrect part numbers for a 2 wheel drive. These are all direct from the master parts listing PDF on this site from the series 9,10,11,12 four wheel drive.
PostPosted: Mon Feb 12, 2018 9:39 am
I believe i have the correct bearings. Thank you very much for finding that. I will see if i can find one to match it
PostPosted: Sat Mar 03, 2018 12:00 pm
I am still looking for one more bearing ring. Party number 94027754
PostPosted: Sun Mar 04, 2018 11:02 am
Joey might have them. Try messaging Wildluvracing.
EDIT....Joey will see if he has them later today
PostPosted: Sun Mar 04, 2018 12:00 pm
I am heading to the shop shortly I will check it out.
PostPosted: Sun Mar 04, 2018 12:05 pm
Great. Thank you very much
PostPosted: Sun Mar 04, 2018 12:38 pm
Sent you a message
PostPosted: Sun Mar 04, 2018 2:17 pm
Looking at the parts book 73-80 2WD is the same spacer for drums and rotors. The 4 X stuff is differant
PostPosted: Sun Mar 04, 2018 2:21 pm
Ya i am looking for a 79 4 wheel drive
PostPosted: Sun Mar 04, 2018 5:43 pm
I have a couple 4x4s I'm parting out.
PostPosted: Sun Mar 04, 2018 5:48 pm
If you have the part i would be interested
