It is currently Sat Jun 20, 2026 12:05 pm
 Post subject: Bagged luv with a 4.3
PostPosted: Tue Feb 06, 2018 11:17 pm
Im sorry If this has already been answered. I could not find it. If you put a 4.3 into a bagged luv how do you lay it out without hitting the oil pan. I ask because once mounted the oil pan sits below the cross member... Thanks ahead of time!
PostPosted: Fri Feb 09, 2018 9:27 am
I would imagine that's all dependent on how you install your engine mounts. Might need some spacers in there to lift the engine up.
PostPosted: Fri Feb 09, 2018 11:14 am
I thought of that but it would require cowl hood, raise transmission, raise driveshaft and trans tunnel. Is there anybody on here that knows if there is a low profile oil pan to fit the 4.3...thx
PostPosted: Sat Feb 17, 2018 2:59 pm
Searched high and low. Only things I can find other than stock are ones with extra capacity (makes your situation worse) or ones that have pan coolers built into the bottom (again, not much help for you).
Sorry man, hopefully someone else comes up with better Google-fu than me.
