It is currently Tue Feb 03, 2026 10:59 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Mon Feb 20, 2017 8:57 am
Popped the valve cover to see what it looked like inside, and tore the rest of the accessories off so I could clean and paint the block.
Since I won't be using the power steering or vacuum pumps that ran off the cams, I made blockoff plates for them.
Saturday was beautiful out, so I gave the block another scrub down, and hit it with a coat of paint. Also did the valve cover in VHT wrinkle finish. Turned out pretty sweet!
PostPosted: Mon Feb 20, 2017 5:24 pm
Are you running a/c?
PostPosted: Mon Feb 20, 2017 5:41 pm
Negative. This thing is going to be as simple as it gets. No A/C, radio, ect.
I want to keep it as light as possible without going to crazy, so anything non-essential is getting tossed.
PostPosted: Mon Feb 20, 2017 6:58 pm
Gotcha I'm excited to see the engine sitting on the frame. I bagging my luv right now and if your engine/trans choice doesn't fall below the frame I'm going to have to do this also.
PostPosted: Wed Mar 01, 2017 6:42 am
Scored a set of MG bucket seats for this. I think they fit pretty well.
PostPosted: Tue Mar 28, 2017 6:43 am
Got some more things for the motor. Exhaust housing, turbo manifold, and wastegate all came in. Ordered my turbo, which is currently backordered. Also had a 90* elbow made to bring the turbo placement up and in your face.
Got my transmission a while back also, and currently have a line on a bellhousing. Just waiting for the guy to pull it so I can pay him.
PostPosted: Sat Apr 15, 2017 12:17 pm
did this die??
PostPosted: Sun Apr 16, 2017 1:22 am
the MG seats look good! engine looks nice all clean and painted up!
1976 Luv
1980 Isuzu kb 4x4
Nissan GU Patrol
Ford Falcon AU ute
PostPosted: Mon Apr 17, 2017 6:37 am
twin 80s wrote:
did this die??
Nope! It is going to slow down now that the weather has turned. House projects take precedence. I also pulled my other truck out of hibernation, so it has been getting some attention since I neglected it all winter.
My '09 5.3 Colorado. Cammed, stalled, bolt-ons, tuned. Its a fun little weekend warrior.
Finally got a bellhousing of of eBay, so now I can mate the motor and trans.
Also, my turbo finally showed up after being back ordered for almost 2 months.
PostPosted: Mon Apr 17, 2017 5:44 pm
How similar to the LNF blocks are these? Do they have the same oil pan? I've been kicking around the idea of a 2.0 turbo swap. We have a second gen Cobalt SS (turbocharged), and it's an angry little car. I can only imagine what that kind of power would be like in a RWD LUV!
Hannah - '79 4WD, 32/36 Weber, and a Pacesetter header. :D
PostPosted: Tue Apr 18, 2017 6:20 am
Same motor for the most part. This is essentially an LSJ (supercharged variant) that Saab threw a turbo on. I wanted to go with an LNF at first, but they are pricey, and this motor ended up being "free" once I sold off parts from the donor car.
PostPosted: Thu Jun 01, 2017 8:40 pm
any updates?
PostPosted: Wed Jun 07, 2017 5:56 am
lspower wrote:
any updates?
Not really. I put the body on the frame so that I can dolly the truck outside when I need garage access.
Found a Dana 44 that I think I am going to use for the rear end. Just need to go pick it up.
PostPosted: Thu Jun 08, 2017 6:29 pm
nice! that's progress!
PostPosted: Tue Aug 22, 2017 9:20 pm
Do you have the engine/trans in the frame yet?
PostPosted: Thu Aug 31, 2017 5:36 am
Not yet. Still focusing on the house and Colorado for a couple of months before I get back onto the Luv. I have been acquiring parts and information still. Got a brand new windshield and found a solid back window.
Sucks that Photobucket wrecked all of my build threads across many forums. Greedy bastards.
Users browsing this forum: Google [Bot] and 27 guests
