It is currently Wed Mar 04, 2026 12:20 pm
PostPosted: Mon Nov 19, 2012 7:33 pm
nairb2 wrote:
Ok, thanks for the info. Just to clarify, do I'll be running the seafoam directly to the ip not through the filter first right?
That's what I'd recommend, but you REALLY have to make sure you've cleaned off the lines before you dunk them into the SeaFoam can. If you rat it through the filter, you'd end up diluting the SeaFoam with fuel. And if you don't route the return line (the one that goes BACK to the tank) back into the can, most of the SeaFoam goes back to the fuel tank...you'd drain that can in a big hurry.
PostPosted: Fri Nov 23, 2012 6:24 pm
Alright so we ran the truck off of Seafoam today. I may need those IP removal instructions :(
- There was no apparent change in idle speed/throttle response.
- A good amount of white smoke. I was expecting black from stuff being cleaned out.
- Nothing appeared to be coming out of return line. Could that be an injector problem? Unburned Seafoam passing through causing the white smoke?
- My Dad noticed oil leaking and exhaust coming out of the crankcase and thought that might be a PCV problem. Is that issue separate from the IP?
Brian
1982 Chevy LUV Diesel 4x4
119,208 miles as of 5/6/2017
PostPosted: Fri Nov 23, 2012 7:06 pm
It was the pump we were hoping to clean out, and that wouldn't necessarily make black smoke.
The injectors may not be perfect, but these trucks seem to be really forgiving. I wouldn't worry (yet) about this.
It's normal for some exhaust to come out via the draft tube on the passenger's side of the motor. Some oil may also come out, ESPECIALLY if it was oveffilled.
Pump removal is a couple of steps beyond timing belt removal. At this point, it would be much easier to point you to that topic at IsuzuPup.com rather than me trying to write a how-to guide here. Once the timing belt is off, there are three bolts holding the pump's mounting flange (they surround the pump's drive gear), and there are two bolts on the adjuster on the bottom of the pump. And of course the injection pipes have to come loose.
Just be aware, you're about to sink about $600 into this project on the pump alone. Now is probably a good time to think through the "what-if" questions. You may still have other issues that are frustrating. Better to decide what your tolerance level is before spending the $600. If you're committed to it, then I'll help any way I can.
PostPosted: Fri Nov 23, 2012 8:19 pm
i have what i believe to be a working pump here
PostPosted: Sun Nov 25, 2012 2:01 pm
Thank you for all your help up to this point. This is a family truck so for sentimental reasons and just to own an awesome 4x4 diesel I think the cost and time will be worth it. It ran perfectly fine before it was allowed to sit so I'm hoping there's not too much else wrong other than the pump and body/interior work. I'll need to save up for a while before I can afford to make much more progress, but if and when I get started I'll let you know.
I suppose that's an option to consider. Though since I plan on putting a lot more miles on this truck I'd be more confident in its lifespan getting my current pump overhauled.
Brian
PostPosted: Sat May 06, 2017 1:09 pm
Hey everyone. I absolutely can not believe it's been 5-ish years since my last post here. Happy to finally be able to post an update.
Long story short, the truck is running! I've only driven about 20 miles so far, but everything seems good. Posted some pictures on imgur.com: http://imgur.com/a/KrltY
Things done:
- Disassembled, cleaned, resealed, and reinstalled injection pump.
- Had to replace the fuel cut solenoid.
- Changed timing belt.
- Changed oil filter and oil with a regular 30w thinking I’ll do another quick change soon.
- Changed fuel filter.
- Flushed and filled brake fluid.
- Drained coolant. Have water in there now with the intention of doing a flush soon.
- Replaced vacuum pump oil hose.
- Re-foamed/upholstered seat.
Questions:
- Truck has been sitting for maybe 7 years now, any recommendation on what I should do before driving it more?
- Do the transmission and differential fluids need to be changed? There are no noticeable leaks anywhere, but wondering if either fluid degrades just sitting there.
- Should I do any sort of engine clean? Like putting a few oz of SeaFoam in with the oil?
- When I change the oil again, what oil should I use? It looks like people on these forums like the Shell Rotella brand. What grade would you recommend? Should I stick with the 30w or go to 15w-40? The temp here in southern AZ during the summer ranges from 60’s to 100’s. Also, how important is getting diesel grade oil? Asking because I just have regular 30w in there now.
- Thank you!
Here’s the long story if you would like to read:
After another several years of the truck just sitting there, I finally decided to do something about it. Went ahead and did everything myself (with the help of my brother) instead of sending the pump off for a rebuild. Hoping to get that done at a later date, though.
So I studied up on diesels, and the injection pump especially. Found a source for seals, an exploded parts diagram, and videos/write ups about the VE type pumps and got to work.
This pump parts diagram and list was most helpful: https://fuel-inject.com/zexe/1047491190/
We pulled out the injection pump and took it apart, cleaned it all up using Simple Green, brake cleaner, and acetone, with a toothbrush and put it back together with new seals. In order to do this you have to buy or make some special tools. I used a Dremel to modify a 6-sided 12mm socket to fit the two 3-sided hinge pins. Then I used a hacksaw to modify a 14mm (I think) nut to fit on the governor shaft locking nut. I measured the positions of the governor shaft, full load screw, top speed screw, idle screw, and control shaft before taking anything apart, then did my best to put everything back to those spots on reassembly.
There was a slight issue while tightening the distributor head down into the pump housing...I failed to make sure the spring seat was fully seated around the plunger aaaand the seat cracked. Thankfully I was able to order a replacement from Oregon Fuel Injection. They appear to be a good source for parts and they were very responsive too. Everything else went well. The cleaning took a while alternating between soaking and scrubbing with that toothbrush, and because we were doing it piece by piece trying to remember where everything goes. The pictures show how full of crud the pump was. And the cause of the high idle and no throttle response issue was the metering sleeve was glued stuck in the full load position, covering the relief port on the plunger.
With everything clean and assembled, we tossed the pump back into the truck doing our best to line up that timing mark on the pump flange, and replaced the timing belt. Put everything else back on, primed it, and she started right up! The throttle response was back and everything sounded good. The only thing was the idle still seemed a bit high. I bought a cheap laser tachometer to measure the crankshaft rpms and it was going about 1200 rpm if I recall correctly. I found the issue was I installed the throttle lever one tooth too tight onto the control shaft. A simple in-truck pump adjustment. Then a slight adjustment of the full load screw and I was able to bring the idle down to 750 using the idle adjustment screw.
I changed the oil and thought everything was all set. Wellllll, not quite. We had the truck idling while we looked everything over and all of a sudden a bunch of oil dumped on the ground (onto a large piece of cardboard we had there just in case). After some research on here and isuzupup.com I figured out the oil hose that feeds the vacuum pump cracked near where it connects to the engine when we moved the alternator to take off the belt. Saw that JLemond might keep some stock of that hose, or there was a post about someone making their own using a 6" length of 4AN braided stainless hose with one M8x1.25 and one M10x1.5 banjo fittings, reusing the original bolts. I went the stainless route for the longevity and it looks good.
Nowww I'm thinking everything is all good. Took it for some short drives in the neighborhood and it seemed fine. Then I decided to go a bit further, grab some more diesel at the corner gas station, and drive around the block. I had just turned off the main street into the neighborhood when my brother and I heard a "pop" in the engine compartment and the truck just shut off. It seemed like the two happened at the same time. When I opened the hood I thought I smelled something like burnt plastic, but didn't see anything out of the ordinary. Thought maybe it was air in the lines so we tried to prime it and start again, but no go. So we towed it back to the house using my brothers Civic+rope, and stopped for the day. The next morning, I googled the symptoms and found people talking about a blown fuel cut solenoid being a possible issue, so that was on the list of things to check. The popping turned out to be the cap on the coolant overflow reservoir popping off. I think that just happened because I had mostly all water in the radiator and maybe some air, so the pressure backed up into the reservoir forcing the cap off. Not 100% on that but everything seems fine since then.
First, I checked the fuse box and noticed the 15 amp "regulator" fuse was blown. Replaced that and tried to start the truck, no go. Just to be clear, the starter is cranking but no ignition. Pulled the oil filler cap off and checked the valves were moving while cranking, just to make sure the timing belt was good. Then I took a jumper wire and tried to jump the fuel cut solenoid to listen for a click. There was nothing there. But I did notice the connection on top looked damaged and smelled a little burnt so I pulled it out. Used a voltmeter to test for resistance between the connection on top and the body of the solenoid (ground) and got nothing. So that was busted. Not positive why, but we could have damaged it while cleaning. Can’t remember doing so, but maybe I submerged it in the and got some water in the coil area? Anyway, I found a replacement on ebay, installed the new one, primed the system, and it started right up! To this point, that was the last mechanical issue I had to deal with. Driven about 15 miles since with no issues.
During all of the waiting for parts to arrive, I flushed and filled the brakes, did some miscellaneous interior cleaning and a quick seat reupholstering. For the seat I got some hog rings, hog ring pliers, and Dap contact cement, and used some carpet padding, burlap, and 3” foam (not sure what density, feels medium) all from Home Depot. Tore off the old stuff, washed the frame and springs, laid a piece of padding down with a few hog rings, glued the foam on top, and covered it with the burlap pulling that as tight as I could. Finished it off with an inexpensive bench seat cover from O’reilly. I think it came out looking and feeling pretty nice. Maybe should have used 2” high density foam, and not sure if burlap was the right thing to cover it with, but it was inexpensive and is comfortable so we’ll see how it goes.
So that’s that! Still have several things on my to-do list. Should probably make sure everything is lubed, flushed, filled. I don’t think the heater works, nor do the reverse lights. The turn signals and emergency flasher works but that multi switch is pretty well worn. The horn piece that touches the back of the steering wheel doesn’t make proper contact, and the windshield wiper part of the switch is totally broken.
Any thoughts/recommendation on what’s most important to do next? Or is it pretty much just all of the above?
I want to say thank you to everyone here and at isuzupup.com for being so helpful and creating such a great resource for people working on these things! Very much appreciated.
Brian
PostPosted: Fri May 12, 2017 1:10 pm
Thought I'd add a video and photo before and after comparison.
Original high idle/no throttle response:
Good idle and throttle response after the fix:
Plunger and metering sleeve (circled) before cleaning:
Plunger and metering sleeve after cleaning:
Brian
PostPosted: Fri May 12, 2017 4:45 pm
Nice work! That one might have gone to the salvage yard if it had been in anyone else's hands. Looks like it may have some years left now. :)
PostPosted: Tue May 16, 2017 9:31 pm
Thanks Jack! Pretty happy with it, and it's very interesting to learn a bit about how this truck works.
Got a few more things to do before I'm comfortable driving it much. But I'm excited to get it on the road for a trip around town and see what the mpg is. Will give another update when that happens.
Brian
PostPosted: Fri Jun 02, 2017 5:03 pm
Went 123 miles on 3.799 gallons, so 32.377 mpg's :smt023
I think I can expect a little more than that moving on because this 123 miles included idling in line at the emmisions test place, and my getting accustomed to driving it. Pretty sweet though!
Brian
PostPosted: Fri Jun 02, 2017 5:29 pm
Do you still need a turn signal / hazard / wiper / dimmer / horn combo switch?
PostPosted: Fri Jun 02, 2017 6:12 pm
I'm not 100% sure on that. Was wanting to pull it off and see if I could fix it before buying one. Found them on Amazon and RockAuto.
The turn signals, hazards, and brights work. The horn works intermittently and is weak sounding, and the wiper and wiper fluid switches are apparently busted. Not sure if it's fixable but figure it's worth a shot.
Brian
