It is currently Tue May 26, 2026 10:26 am
Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2, 3  Next
 Post subject: Greek restoration kb25
PostPosted: Sat Apr 15, 2017 3:30 pm
Hello guys from Greece.
I am trying to restore my dad's luv.It is an 1980 rwd greek import with a greek made bed.
It is in a pretty bad shape cause of the rust.
I am looking for a good bed and if not i will repair this one.
Also both driver's and passenger's floor are rusted.
Anybody knows of what other cars radiator fits to luv.
Also anywhere i can find rebuilt kit for the nikki carb?
Here are some pics of what i've done far.
PostPosted: Sat Apr 15, 2017 3:33 pm
https://postimg.org/gallery/12vcreyw4/
PostPosted: Sat Apr 15, 2017 3:35 pm
If anyone can modify them so they appear straight to the site i would be thankful.
PostPosted: Sat Apr 15, 2017 9:48 pm
PostPosted: Sat Apr 15, 2017 9:49 pm
Welcome. Looks like you've got a good start on it.
PostPosted: Tue Apr 25, 2017 12:39 pm
https://postimg.org/gallery/2esl6stzy/
PostPosted: Mon May 08, 2017 10:48 am
Big problem guys....
What is the way to fix it?
Do i have to get the head out?The oil pan?
PostPosted: Tue May 09, 2017 10:07 pm
Is that the block that is busted? Time to do a swap.
PostPosted: Wed May 10, 2017 12:02 am
it s the timing cover.Manual says that head and sump must get out in order to remove it but i read here some guys saying that is possible doing it on the car without removing the head.
I would love a swap but the v8 here are ultra rare engines.
PostPosted: Fri May 12, 2017 9:23 am
need some help guys.
is there a timing mark on the crank pulley?
Any pic of it?
How do i find #4tdc?
g161z engine
PostPosted: Sat May 13, 2017 10:54 am
One more question.How do i check the chain?In the manual says i measure 40 links from pin center to pin center.Does it mean from the center of each link or something else?
PostPosted: Sat May 13, 2017 8:06 pm
In the US, there wasn't a G161Z option so not many of us know anything about them.
Send oldestisuzuist a PM. He might know something about this motor. Or he might know someone who does.
PostPosted: Fri Jun 02, 2017 9:06 am
Today i put back the timing cover with a new oil pump.I set the pump's mark as the manual says but although the shaft is not parallel with the front of the engine.
Bacause i am not planning getting the cover out again if i change the ignition wires among the cylinders will that be ok or no?
PostPosted: Fri Jun 02, 2017 11:54 pm
I recently did a timing cover, and if I'm not mistaken the distributor will be a tooth off
Yellow 74 LUV. Factory a/c
White 79 LUV. Factory a/c
Tucson, AZ
PostPosted: Sat Jun 03, 2017 6:19 am
i found on internet that the oil pump can be removed with not taking the cover off.Is that right?
PostPosted: Tue Jun 13, 2017 10:29 am
Not sure on that, but when I did all that I had the engine out and on a stand. It seems to me that it would be easier to do it with the engine out of the car. Especially when it is something so important with the timing and the oil pump
Tucson, AZ
PostPosted: Wed Jun 14, 2017 12:02 pm
In the end i removed just the oil pump from under the car and put it back the right way.
Bought a set of new spark plugs and wires and i ve noticed that the main wire from the coil to the distributor leaks current.It hitted me a couple of times.
I ve used a multimeter and it shows 1volt when i grounded it.Same with the old wires.
Any ideas what the cause could be?
PostPosted: Sat Jul 15, 2017 4:46 pm
little update
PostPosted: Sun Jul 16, 2017 10:23 am
2 more
PostPosted: Fri Jul 21, 2017 12:19 pm
anybody can guide me on how to remove the door weather belts?
