It is currently Thu Jun 25, 2026 11:42 pm
 Post subject: Timing help
PostPosted: Mon Jan 30, 2017 4:06 pm
I'm trying to time my 75 chevy luv and thr sticker under the hood says 6 degrees btdc but my balancer on has 4 marks. What does each of the marks represent?
 Post subject: Re: Timing help
PostPosted: Tue Jan 31, 2017 1:08 pm
GOT PICS ? ..Pics help us see what your working with ... I looked it up in the series 4 shop manual > ( & have a spare manual if you need one) it shows 3 marks ..hope this helps you ...18
PostPosted: Wed Feb 01, 2017 6:14 pm
75 Luv timing is 12 degrees btdc as in the picture not 6 degrees. 76 and up are 6 degrees btdc.
PostPosted: Thu Feb 02, 2017 2:48 pm
i can grab a pic and post it after work, and ohh the sticker uner my hood said 6* so thats what i thought it was.
PostPosted: Thu Feb 02, 2017 10:21 pm
pics just help other see what your seeing
marks represent?
MAYBE That is not the stock 75 hood / Sticker
PostPosted: Fri Feb 03, 2017 6:22 am
A good way to determine the correct timing is to identify the motor. The 72-75 motors have the intake an exhaust on the same side and the timing should be 12°. The 76-82 motors have the intake and exhaust on different sides. It's possible you may have a 75 titled as a 76 or vice-versa.
PostPosted: Fri Feb 10, 2017 11:12 pm
It turned out there was only 3 timing marks and i checked my manual and it said 12* to so i think i might have a later model hood. But my engine does have both intake and exhaust manis on the same side. I got my petronix installed and all timed and its running good.
Users browsing this forum: Baidu [Spider] and 51 guests
